FZJ80 Power Steering (Vane) Pump question
Hey there, just needed some help with my power steering pump. Does anyone happen to know what this allen head thing is called and what it is for (Circle in green)? I’m driving a 95 Land Cruiser. Thank for you help with this.
Get the Gates Kit on Rock Auto and rebuild your old one.
I don't remember that Allen Head when I did mine.
^2
It's a bore/galley/passage plug, not intended to be serviced.
Really hey? Damn mine seems to be missing. Well at least part of it. The plug is still there but the Allen head piece that holds it is missing. Thx for the reply.
Some have an allen, others have a press in plug. Was fluid pouring out there, if not and it has a plug, wouldn't worry about it. Shoot/post a picture of it.
If it is not leaking:
Leave it be
If it is leaking:
Take the plug out and get a replacement at Fastenal (Likely NPT threads), Wrap with Teflon Tape and Replace.
If Allen Head is gone. Drill into it and use a Irvin Bolt remover to twist it out.
It is very hard to weld in place if plug is steel and body is cast iron (I'm unsure)
My guess: Most that we see have a smooth bore, no threads, with a press in plug, that is deeply set, factory. A few have had the allen, like in your picture, close to flush, this maybe done by a re-builder? Your pic is from a re-builder Cardone?
Yes I pulled it off the web for reference. Here's my actually plug. Sorry for the lame shot. It would make sense if it were a press fit. Can't seem to feel of see any threads.
So if oil is pouring out, what has caused this plug to pop out and is it fixable if it's a non serviceable part?? Or do we get a new pump?
After trying a few things I ended up just getting a new pump. From what I gather, since it was a press fit design, the sealant most likely deteriorated over time. I'd suggest getting a new pump just for the piece of mind.
I sealed up that hole/galley with JB weld after my pump started pouring fluid out of it. The JB weld worked surprising well until I forced another leak :bang:
