FZJ80 Power Steering Fluid
Wisconsin
Replaced my leaky low pressure power steering hose and put a new power steering pump in over the weekend. How much ATF does the power steering system hold? I neglected to notice how much fluid I drained when replacing the pump and hose. So far I've added 1 Gallon and 1 quart and the reservoir is still empty.
Hmmm. Just finished doing mine too except I replaced all of the low and high pressure hoses as well, and it took around 1 quart. You might have a leak somewhere as 1 gallon seems like a lot. I'm in Ahwatukee where in Phoenix are you? Ned
I did pump and low pressure hose and used 1 Qt of Synthetic ATF.
I put truck on Jack Stands and turned wheel from LH Stop to RH Stop with truck off to bleed as someone mentioned on here.
No noise, No Bubbles, No Issues.
When my pump failed I tried driving without and I'm not a wimp, and could barely turn wheel.
Well crap. Any idea where it would be leaking? No drips on the ground at all. If the engine is running I get small bubbles in the atf in the reservoir. Engine runs fine. At this point anything is possible, the previous owner did basically no maintenance.
That sounds strange that you have added over a gallon of fluid and haven't seen anything leak. From empty to full takes about a quart, maybe a little more. Can you post a picture of your reservoir?
If it's leaking and not hitting the ground, it's most likely the front seal in the pump. If so, it's leaking into the crankcase, is your oil level high?
I checked all fluids again just now in case somehow the power steering fluid is leaking into another area, oil is at the full mark and looks like oil, clean, same goes for coolant.
When adding fluid, the reservoir will fill. I'll then start the engine and turn the wheel lock to lock. Check the reservoir and it will be empty again.
Pictures of my reservoir:
Imgur: The most awesome images on the Internet
My oil was clean but this seems to be the most likely issue. I'll pull the pump later this week and check everything. For now I'm going to leave it parked.
Assuming this is the case, is ATF ok to set in the crank case for a few days? Or should I drain the oil?
When adding fluid, the reservoir will fill. I'll then start the engine and turn the wheel lock to lock. Check the reservoir and it will be empty again. ...
That is how it works on a low/empty system, but it shouldn't take anywhere close to 1.25 gal. It has to be going somewhere, it can leak on the ground or into the crankcase.
I ended up taking the LC to a mechanic friend as I've been really busy with work and didn't have time to work on it. Long story short, the ATF was leaking into the crank case. Unfortunately the power steering pump bit the dust from not having enough fluid.
New power steering pump, a quart of ATF and an oil change and I'm back in business. Thanks again for everyone's help in troubleshooting!
Dang that sucks. At least you are back in business.
