THEFT DETERRENT
84
THEFT DETERRENT SYSTEM
To deter theft of the vehicle, this system is designed to
sound an alarm and keep the engine from being started
if any door is opened while the system is armed. An
alarm will also sound if window glass is broken or if
power to the system is interrupted then restored while
it is armed.
When triggered, the vehicle’s horn sounds and the exterior
and interior lights flash in a unique pattern. Perhaps more
importantly, the vehicle’s starter is disabled at the same time,
preventing engine start.
Arming the system
1. Turn the ignition key to the “LOCK” position and
remove it. (The system will not arm it the key is left in the
ignition switch.)
2. Exit the vehicle and close all of the doors. (The
system will not arm if any door is open.)
3. Push the transmitter’s top button.
At the same time the “Theft deterrent system” arms, the
doors will lock, the tail and marker lights will flash once, and
the buzzer will “chirp” once.* Also, the vehicle’s interior lights
will come on for 3 seconds**, and the status monitor’s LED
will begin to flash steadily.
After using the transmitter to arm the system and lock the
doors, you must use it to unlock the doors and disarm the
system. Otherwise, the system will be triggered and an
alarm will sound.
Note: Manually locking the doors by key outside the
vehicle will not cause the “Theft deterrent system” to
arm. The “Theft deterrent system” can only be armed
and disarmed using the transmitter.
4. After confirming that the system is armed (tail and
marker lights flash once the buzzer “chirps” once), you
may depart from the vehicle.
Never leave anyone inside the vehicle when you arm the
system, because opening a door will cause the alarm to
sound.
* If a door is open when you push the transmitter’s top
button the “Theft deterrent system” will not arm (and the
doors will not lock). Instead, the buzzer will sound for up to
10 seconds or until the open door is closed securely.
** So long as the interior light switch is set to the “DOOR”
position.
When the system is armed
ALARM TRIGGERING
While the system is armed, the alarm will sound and the
vehicle’s starter will be disabled under the following
conditions:
If any of the doors are opened.
If the window glass is struck and/or broken.
If power to the system is interrupted (for example, due to
a dead battery or a blown fuse) then restored.
After about 1 minute, the alarm will automatically stop and
reset, but the vehicle’s starter will remain disabled until the
system is disarmed.
ALARM TRIGGERING BY THE GLASS BREAKAGE
SENSOR
A specially tuned microphone is mounted in the status
monitor next to the LED. This microphone is tuned to detect
the sound of tapping on or breaking of the vehicle’s window
glass. The sensor has been specifically adjusted by the
factory for your vehicle.
The glass breakage sensor triggers the system in two ways:
1. When the sound of tapping or breaking of glass is
detected, the system will first sound the alarm 3 times as a
warning.
2. If the glass is tapped on or broken within 5 seconds of the
first detection, the system will trigger for about 1 minute.
REACTIVATING THE SYSTEM
After the alarm has been triggered, the system will reset
itself. The alarm will sound again under the same
circumstances as listed in “Alarm Triggering”. Once armed,
the system can be triggered and reset 10 times and the
alarm will sound. After the system has been triggered 10
times, the alarm will no longer sound, but the vehicle’s starter
will continue to remain disabled.*
* After disarming then arming the system, the alarm can
sound again.
STOPPING THE ALARM
Push the transmitter’s top button once.
The alarm will stop, the doors will unlock, and the vehicle’s
starter will work again.
OR
Insert the key into the ignition switch, and turn it to
“ON” twice. (“ON” " “LOCK” " “ON”)
The alarm will stop, and the vehicle’s starter will work again.
Note: Pushing and holding the transmitter’s top
button for more than 2 seconds activates the Panic
Mode. For additional information, see “Sounding an
alarm (Panic Mode)” on page 9.
Status Monitor LED
The status monitor’s LED gives the following two indications:
FLASHING – The system is armed. You need the transmitter
to disarm the system and unlock the doors.
OFF – The system is inactive. You may open any door.
Testing the system
1. Open all of the windows.
2. Arm the system as described in “Arming the
system”.
The doors lock, and the status monitor’s LED will flash.
3. Open a door from the inside
The system will be triggered when the door is opened and
the alarm will sound.
4. Push the top button on the remote control
transmitter.
This will cancel the alarm.
5. Repeat steps 1 through 4 for the other doors.
If the system does not work properly, have it checked by your
Lexus dealer.
5
SECTION 1 – 1
INSTRUMENTS AND CONTROLS
Keys and doors
Keys 6
Wireless remote control transmitter 7
Ignition switch–activated automatic door lock/unlock 10
Side doors 11
Side windows 13
Back door 14
KEYS AND DOORS
6
KEYS
Master key – The master key works in every lock.
Subkey – The subkey will not open the glovebox.
Key number plate – Keep the plate in a safe place
such as your wallet, not in the vehicle.
To protect things locked in the trunk or glovebox when you
have your vehicle parked, leave the subkey with the
attendant.
Since the doors and trunk lid can be locked without a key, you
should always carry a spare master key in case you
accidentally lock your keys inside the vehicle.
If you should require replacement or additional keys for any
reason, contact your Lexus dealer.
You should also put a copy of the key number with your
important papers.
Insert your flat key in its key case as shown. We recommend
that you always carry this with you as a spare. Do not leave
it in your vehicle.
NOTICE
Do not let the key case become bent as the key may
fall out or become bent also.
The flat key is designed for emergency use only, so
do not use it regularly instead of the other master
keys.
KEYS AND DOORS
7
WIRELESS REMOTE CONTROL
TRANSMITTER
This transmitter has 6 functions.
1. Locking the doors . . . . . . . . . . . . . . . . . . . . . . . . .
2. Unlocking the doors . . . . . . . . . . . . . . . . . . . . . . .
3. Programming the buzzer
operation (on or off) . . . . . . . . . . . . . . . . . . . .
4. Sounding an alarm (Panic Mode) . . . . . . . . . . .
5. Arming the “Theft deterrent system” . . . . . . . .
6. Disarming the “Theft deterrent system” . . . . .
The operational range of the wireless remote control is
approximately 7.5 meters (25 feet). The effective range may
vary with different conditions.
When handling, take care of the following:
Avoid getting the transmitter wet.
Avoid striking the transmitter against any other objects.
Locking/unlocking the doors
(a) Locking
After exiting the vehicle, push the top button on the
transmitter. All of the doors will lock, and the buzzer will
“chirp”.
If any door is not securely closed, the vehicle’s buzzer will
sound for up to 10 seconds, or until all of the doors are
closed. After the doors are all securely closed, you must
push the transmitter’s top button again to lock them. Also,
door locking can not be done if the key is still in the ignition
switch.
At the same time the doors lock, the tail and marker lights
flash once, the interior lights come on for 3 seconds,* and the
“Theft deterrent system” arms. For further information, see
“Theft deterrent system” on page 84.
*So long as the interior light switch is set to the “DOOR”
position.
Note: If the transmitter is used to lock the doors, it must
be used to unlock them as well.
The “Theft deterrent system” arms every time the doors
are locked by using the transmitter. If you were to use
the key to unlock the doors and enter the vehicle, the
“Theft deterrent system” will trigger. The system
cannot be disarmed by unlocking the doors with a key.
KEYS AND DOORS
8
(b) Unlocking
To enter the vehicle, push the top button on the
transmitter.* All of the doors will unlock, and the buzzer
will “chirp” twice.**
Together with the doors unlocking, the interior lights will
come on for 30 seconds or until the vehicle’s doors are
closed. At the same time, the tail and marker lights will flash
twice, ** and the “Theft deterrent system” will disarm.
You have 30 seconds to open a door after using the remote
unlock feature. If no door is opened within 30 seconds, they
will automatically re–lock, and the “Theft deterrent system”
will re–arm.
*If the doors were locked without using the transmitter, you
must push the transmitter’s top button twice. The first time
it is pushed, the “Theft deterrent system” arms.
**If the tail and marker lights flash 3 times and the buzzer
“chirps” 3 times, this indicates that the system was triggered
and the alarm sounded while you were away from the
vehicle.
Turning off the buzzer
The factory setting for the buzzer’s operation is ON (the
buzzer “chirps” when the doors are locked and unlocked).
When the buzzer has been turned off, its operation is
affected only during remote control door locking and
unlocking.
To change the buzzer operation, follow the steps below:
1. Insert the key into the ignition switch, and turn it to “ON”
(not “ACC”).
2. Using only one remote control, push and hold both
buttons (at the same time) for over 2 seconds, until the status
monitor’s LED turns on.
KEYS AND DOORS
9
YOU MUST PERFORM THE NEXT STEPS WITHIN 30
SECONDS.
3. Select the operating mode.
To turn the buzzer off: Push the bottom remote control
transmitter’s button twice. (The buzzer “chirps” twice and the
exterior lights flash twice.) Turn the ignition switch to the
“LOCK” position.* (The buzzer “chirps” 3 times and the
exterior lights flash 3 times.)
To turn the buzzer on: Push the bottom remote control
transmitter’s button once. (The buzzer “chirps” once and the
exterior lights flash once.) Turn the ignition switch to the
*If you do not turn the ignition key to “LOCK”, or if you exceed
30 seconds during the programming steps, the status
monitor’s LED will turn off and the previous operation mode
will remain unchanged.
Pushing and holding the transmitter’s top button for
over 2 seconds will cause an alarm to sound to deter
any person trying to break into or damage your vehicle.
At the same time the alarm sound, the tail and marker lights
flash and the interior lights flash.* Also, the doors will lock or
unlock (depending on their status when the Panic Mode is
activated**). You may activate this alarm at any time, even
while driving.
position.
**If the doors are locked when Panic Mode is activated, they
will unlock, then lock again. If the doors are unlocked when
Panic Mode is activated, they will lock, then unlock again.
KEYS AND DOORS
10
If you want to stop the alarm, push the transmitter’s top
button.
Note: Your vehicle’s starter is not disabled during the
Panic Mode alarm.
For vehicles sold in U.S.A.
This device complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions:
(1) this device may not cause harmful interference,
and (2) this device must accept any interference
received, including interference that may cause
undesired operation.
FCC ID: HYQWDT – C
MADE IN JAPAN
! CAUTION
Changes or modifications not expressly approved
by the party responsible for compliance could void
the user’s authority to operate the equipment.
IGNITION SWITCH–ACTIVATED
AUTOMATIC DOOR LOCK/UNLOCK
For your convenience, your vehicle’s doors will
automatically lock when the key is inserted into the
ignition switch and turned to “ON” or “START”. They
will unlock when the key is turned back to “LOCK” or
“ACC”.
Automatic door locking
1. Enter the vehicle and close all doors securely.
2. Insert the key into the ignition switch and turn it to “ON”
or “START”.
All of the doors will automatically lock. This feature will not
work while any door is open; all of the doors must be closed
securely.
Automatic door unlocking
1. Turn the key to “ACC” or “LOCK”.
The automatic unlock feature will not work if a door is
unlocked and opened before the key has been turned back
to “LOCK” or “ACC”.
The automatic unlocking feature will work only if the doors
were automatically locked.
Note: The Automatic door lock/unlock feature will
operate only once (automatic lock, then automatic
unlock) before a door is opened and closed again.
16
