FZJ80 Help
San Ramon, CA
Website
www.nullterminal.org
Hey guys,
Im brand new to these forums and they sound and look like alot of help. I currently just got from my dad, a 1994 Toyota Land Cruiser, Straight 6, AWD, 235000 miles on the thing and i have a couple of questions about it, because recently I have been getting into fixing it up, maybe lengthening its lifespan.
Well here it goes,
1. Is the technical name for my Land cruiser a FZJ80 or FJ80! I've seen pictures of both and cant distiguish if theres a difference between the two.
2. I recently bought a tune up kit with Distrubtor Cap, Rotor, Wires and plugs. Found out that the Air intake tube is majorly ripped, now with it all together (Firing order correct) It shakes when i start it, Is it because of the air intake rip or spark plug gap, or just that (i dont think ever) it has been tuned up and the ECU has just changed the Air/Fuel ratio to what it needed to be when it was running bad)
And finally, thanks for listening,
3. Does anyone know a good company, maybe you have experience with, where you have found a lift kit for my car, preferably 5" lift?
Thank you so much, i Appreciate any input
=D
Trevdawg
1)
Fzj-80 is '94 to '97
FJ-80 is '91 to '92
The Fzj or FJ refers to the engine that the truck has. The Fzj has a larger, more powerful, and more modern engine than the engine in the Fj
3) People around here seem to prefer OME lifts. They have the most common combinations and many people run them. Try sleeoffroad.com for 80 lifts and mods.
Try the search for info, and the FAQ has many answers to common questions (i.e. lift questions, crusier language, etc, etc....)
Lets see some pics of your truck, and as usual, :flipoff2: Welcome!!!
A leak in the air intake tube will cause serious driveability problems, ie. stumbling, running rough.
Heres are some pictures =D
I call her "Betsy"
Got new tires on her since then though.
EDIT: haha, funny story about that little mark there on the fender there, that little ding, that rubbed out, costed this doctor $1300, i was a happy 16 year old then.
You should aquaint yourself with CDAN on MUD. His actual moniker is "cruiserdan" and he can help you out with OEM parts for your FZJ80 at considerable discounts compared to most dealerships or outlets :)
FWIW: replace the air intake tube...a leak will cause all kinds of idle problems. If you choose to repair it, every time you check your air filter, the hose will leak again bringing back the problems...usually at the worst possible times!
The folks on this forum are the greatest! Heed their advice and enjoy your new rig!
