I have an OME kit on my 93 (it was on it when I purchased it) that has 850's and N73' in the front and 863's and N74E's in the rear. I had a stinkbug problem so I put on 2" spacers in the front from Metal Tech and it leveled that puppy perfect for me.
I wanted to add the caster correction kit on the front and after all the searching and talking to the guy at Slee I decided on the Caster Plate kit. When I got it shipped to me and I am looking at it I am having second thoughts. It is recommended to weld the plates which I think is a must but looking at the axle and the new location of the control arms bolt up, it appears that my tie rod is going to rub my control arms and unless I am looking at it wrong it will change the angle of the drive shaft in the opposite direction I would want it.
Am I looking at everything correctly? Does anyone else have a similar setup that is using the caster plates? I am not sure I want to do this. Any comments are welcome and appreciated.
Thanks
Tony
Thanks
Tony
