Build FZJ80 6.5TD diesel swap build thread
Yes, that's correct, the tcase will ground a line from the locker comp and let you operate lockers normally. Since I used a different tcase I had to ground that lead separately,
Sounds like you have a good start, great project!
I am actually considering another one, found a good price on an 80 that needs an engine and it is making me want to do it.
Keep us posted on the build, that is a great engine for the 80.
The thing you need to think about is the gearing again, I went with the 700R4 because it actually had better final drive than the NV4500 if I remember correctly, plus I didn't want to go to the trouble of converting to 5 speed, would be nice though. If the 6.5 is anything like my 6.2 it needs to cruise at under 2,000 rpm, 1,800 is about perfect.
Good luck!
Rusty
With the MFI of a '93, putting together a harness should be pretty simple. The OP has the basics in post #26.
I think is so cool that you did a 6.5 swap. We got a 84 6.2 that's a complete dog. Slow, bulky. But man she sounds mean, and can't beat 22mpg on the freeway out of an 80s truck. Ive looked into it because I love the idea of a diesel inside my 80.
Did you get one of the 6.5s with the interchangeable chips. Also how'd you get around the crappie timing advance system they run on the 6.5s
I know I'm 16 years behind just kinda curious
