Fusible Link HZJ78
Germany
did anybody have pictures from the original Batterie / Fusible Link HZJ78 narrow front ?
I want to build it back to original .
there are more then a few Varisation here on this ?
it is not as easy as just posting you have a HZJ78 ..
perhaps your modle year could be a good place to start .........
🔮 i don't have a HZJ78 Fusible Links Krystal TEq embossed ball 🔮
you need to post TECH photos of your correct set up , or what is left of it ?
also your Model ID code and frame # off the engine bay ID plate , this all helps narrow it down , so i can pin point your specific needs specifically ...
thanks
82627-60020, I believe.
sorry, i try to explain :
20 years ago i was an idiot and cut a lot of wire from the batterie and install a lot of electronic rubbish . now i want to built it back to original an need a few photos from that to reinstall the fusible link and missing wires
with out the complete frame #
i came up with 2 other possible ones , including the 82627-60020 per. Dan
82627-60140 ... is one / i think this is disc. / NLA , but i can handy craft one up if it winds up being this
if its the 82627-60020 , i keep them in-stock and can mail out today , at over night pony express usps or slower if you choose
thanks
matt
thank you, but i do not need parts, i have the fusible Link here in Stock, i need only pictures to install it .
You can log into the Toyota Europe Technical services website and download the electrical wiring diagram which will have the specific wiring diagram as well as wiring routing/colors/connectors, etc. Then you can rebuild it as needed.
