Funny Noise (with audio)
Cincinnati, OH
I hear a funny noise that sounds like chhhh chhhh chhhh and is coming from the front of the engine. I dont usually ear it when I start the LC, but after driving for abit. Its hard to hear it in the video, but its easier to hear towards the end of the video.
It does vary with speed. Would I just change the alternator, is there a method to check where its coming from?
Sounds like a LC with worn out belts.
Do the process of elimination thing? Start cheap. (belts) Think positive. It's a Toyota.
I prefer to not use the WD because it's a dust magnet, get a can of belt dressing and see if the noise temporarily is reduced, (it probably wont entirely dissappear) It you still have a strange noise, then use the garden hose stethoscope. Cycle the AC on and off. etc...Check the water pump. But concentrate on the belts first.
LOL. To each his own; I HATE belt dressing. The kind I bought, at least, seemed like it was basically throwing little tar droplets at the motor. Even my wife (bless her) noticed it; she called me from out of town saying, "Honey, there's some weird black gunk on parts of the engine; is something wrong with it?"
WD 40 instantly and completely (temporarily) stops whines that are coming from belts. Makes for a 2 second diagnosis.
Now here we agree.
Cheers,
Curtis
Check the idler pulley on both sides with the belts off next (once you rule out belts). The bearings in those go bad and you will have the noise I heard.
Use a wooden dowel to touch each major component in turn with the other end close to your ear and you'll ID the source. *Use extreme caution as getting it caught in a belt with one end by your brain can kill you* My bet is the small idler pulley under the A/C pulley. They periodically wear out and are about $20 from Cdan and 15 minutes to replace. More if you search for this here.
DougM
DougM
I agree about listening to each bearing, but a mechanic’s stethoscope is much better and safer. They are readily available and inexpensive.
http://www.lislecorp.com/tool_detail.cfm?detail=958
thanks for the suggestions guys, I will start my quest this weekend when i have some free time.
as described elsewhere, there is a Harbor Freight mech stethoscope that works amazingly well for $5 or so... Has tubing so you won't kill yourself or go veggie when sticking a wooden rod in your brain... :)
