Fun new sound
The Texas Riviera
So I drove from Corpus to Round Rock TX, and back. Good times. It was a good trip and I was using it as a shakedown run before a trip in OCT. I knew it would shake, and shake she does. I figured I needed new shocks, but that is for another thread. This morning I came to work and heard the knock in the attached video, any ideas or suggestions?
Thanks
Dan
The oil pressure was constant the whole time, stayed just below the top tick. That is where it always is. No loss of power. Oil looks good. It increases with the rpms.
A (relatively) easy way to diagnose a rod knock is to disconnect one spark plug wire at a time and start it. If the noise goes away during one of these attempts, you'll know what you are dealing with.
This video shows that method. Personally I don't like doing it with it running. It's best if you arrange the wire so that the spark can go somewhere.
Ok, I got home this morning and used my high tech listening probe (big ass screw driver to the ear). Nothing sounded terribly convincing. On a whim I put it in the alternator and the knock was very pronounced. No problems with the charging system yet but, I am 90% sure that is the source.
No fooling! I also just noticed that I have only one alternator belt, been that way since I bought it. I've owned it for a year, no telling about the PO.
Engine idles around 600 rpm, so that's 10 spins of the crank per second. Alternator pulley is smaller, as a WAG say 3x smaller thank the crank pulley. That means the alternator is spinning around 30 times per second. I'd expect any alternator bearing noises would have a 30Hz 'beat' to them. Your knocking sounds are a lot slower than that - more like around 3 times per second - more in line with each power stroke of a 4 stroke engine...
Anyhow, drop the belts, start the engine and you'll know pretty quickly, hopefully it is the alternator and not the engine - fingers crossed for you.
cheers,
george.
Ok, bullet dodged. While getting in to pull the belts to have a listen this is what I found on the belt, missing from the belt. A chunk of teeth missing. Watching this bit make it revolutions, it is consistent with the sound.
Bad belt - even better/cheaper news :)
A) purchase OEM non-toothed belts.
B) purchase OEM non-toothed belts.
C) etc
cheers,
george.
Yes sir, and if I was taught anything in auto shop, if I'm replacing one belt....
Well, stock OEM should be 2 belts there.... Looks like one was lost a long time ago given how 'not' shiny the idler pulley is in the 2nd belt position (that is missing a belt).
But, yes, I agree, change ALL the belts if you are changing one and in this case add in a belt. Buy as a matched pair from dealer/cdan/beno etc.
cheers,
george.
Just to a quick update, all belts replaced and she sounds as smooth as a good martini. (Now I can hear the exhaust leak). Thanks for all the help and ideas.
As I was reading through this thread, at post #7 and watching the video, I said to myself, this is a belt. I could see a white piece moving at the same speed as the sound and I was going to tell you that I thought it was a belt / idler / adjuster problem, and nothing more serious.
Then I get down to your post #12 and it confirmed it!
Congrats on finding it and it being simple / cheap!
This is the worst of the belt, clearly not oem, and there was only one where two should have been. Now, back to the speedo :bang:.
Owning the 80 reminds me of my dating days, everyday the possibility of a new discovery. We get to see what each other's like and dislikes are, and at least twice a week I will be underneath her.
