Fumes canister
EAST COAST
I noticed when I filled up my oct/74 FJ40 that the cab just reeked of gas. I wont let anyone smoke in my rig. During the rewire I found a hose under the gas tank plate that leads nowhere. I am guessing it used to lead to the fumes canister. Obviosly a po decided this part was not needed. Do you guys think it would be safe to just lenghen the hose and vent it out the back window untill I can find a canister? FJ40'S are pretty rare around here and there are none on e-bay. :beer:
If you look on SOR's websight you can pretty much tell how it needs to be plumbed up. There's usually a vapor separator right near the tank, and then the charcoal canister goes up under the hood. I believe there is a valve somewhere in the mix too. All this was missing from my 79 when I bought it. I got the vapor tank hooked up, but I still haven't hooked up a charcoal canister yet. I'll probably just use one from an old bmw at work.
well in a 69 there is only one line out of the tank thats to the pump and a small vent hole in the fill neck but i with mantis on this one "My solution? Remove the hard top." it by far the best way to get rid of the gas smell.
Form follows function. I am not certain of which fitting you are speaking, but I can tell you this. The basic premise of the charcoal canister is to provide a means to condense the heavier fumes back into gasoline, while routing the lighter fumes directly into the carb.
Sooooooooo, if this line has ONLY [and I emphasize ONLY] fumes, then you should consider putting a fitting onto the air cleaner, past the air filter, that can draw these fumes into the carb and burn them.
If you merely plug this off, the fumes will have to find another way out of the tank, which will not only be smellier, but be a waste of a petroleum product you could be burning.
Not all emissions equipment is bad.
