Full time to part time
Lynden, Washington
I have been searching for information regarding a conversion to part time 4WD. Am I correct in that my 97 LX450 has the HF2A transfer case? I have found out that Marks 4WD has a kit that appears to be what I'm looking for. They claim "Vehicles fitted with viscous coupled centre diffs can be fitted with the part time kit. After replacing the viscous coupling with our new spool 2WD high and 4WD low are made operative. To make 4WD high operative the 4WD switch from a GXL model must be fitted. To fit the switch is easy as all the wiring and the necessary plug are all provided in the Toyota wiring loom." I assume they mean the CDL switch that I have already installed. The following is included in the kit.
MFK1210/80PART TIME 4WD 80 SERIES - Rear centre differential housing, thrust bush, free wheel hubs, 2 axle spacers and instructions. $525.00 Australian. Does this look like the way to go?
:doh: Thank you for the feedback. Talked to Man-A-Fre and they no longer sell it but learned that the kit disables the ABS system when installed. Trying to decide if that is really so important as most 4WD i have owned didn't have it to start with. I just know that a full time system is wearing far more parts and has less fuel mileage then a part time system.
Another way--way cheaper--to go 2wd is to get the center differential lock button/switch, pull the front drive shaft, engage center diff lock, and be 2wd using only the rear driveshaft. Poor man's 2wd.
It'll net you maybe 1mpg more, and some lessened wear on your front end--specifically the birfields. I've been doing this for awhile and just plan an extra ten minutes before a trail run to get underneath the truck and put the front driveshaft back in.
-o-
I see your point but since the wife is also driving this rig I know that when I ask her to put the front drive shaft back on I'm going to get "the look" and all us married guys know what that look is!:D I also think that by having front lockout hubs I would reduce the wear even more then just a driveshaft disconnect.
Also spoke with Slee, and it looks like they sell the same kit that Mark 4WD sells. Thanks for the heads up Bomar.
Aren't you the guy with the ultra-low mileage 80? If so, why bother going to that extra trouble? You have 10-20 years of driving ahead of ya before you encounter any real issues
With the poorman 2wd the birfs will still spin but they won't be under load so perhaps that might help birf wear a little bit.
IIRC, one point someone brought up is that with even with lockout hubs, the birfs/axle shafts are allowed to spin inside the spindle (increased spindle wear) because these are full time tranfer cases even though no power is tranfered to the wheels.
Yes, it does have very low mileage (10,786) and was actually thinking of making it last longer. I'm so used to part time 4WD trucks I guess I thought it would be an improvement. Maybe being a full time 4WD is why they're so great. I remember a full time 4WD K5 Blazer I owned back in the 70's. Worse truck I ever owned on slick roads. Converted it to part time and it improved somewhat. I appreciate the frankness, as a newbie I'm still learning about 'cruisers.
Leave it as is.
It's natural at first to want to go to part-time if that's what you've always driven; I know I went through it. Now I love the AWD; no way would I change it.
Curtis
Having lost my full-time with my cheap front locker...I would say AWD is the way to go. If I could afford an ARB or E-locker then I wouldn't be buying the Part-Time kit. I've been running half way PT; locking the center diff with the hubs in freewheel, and it's more fun...but it doesn't feel as planted in the turns (HD sways or Anti-rock are now in the plans).
It's a trade off I would regret only if this was still my DD, but for the use it gets now a cheap locker and having 2WD to get to the trails works great.
Leave it as is.
Curtis
X2
The 80's system is well designed and when properly maintained, you'll get reasonable fuel mileage. The part time conversions will take years, if not decades to pay for themselves. The heavy duty 80 just requires more energy to move around and improvements to original design are minimal. One thing that might help you to justify running the full time system of the 80 is that in part time systems, part of the drive train sits immobile and unused, often for months at a time. Grease and lubricants can gel or set so when you need to use 4WD, it may only partially work if at all, until it's warmed up or cranked on causing additional wear and aggravation.
Been driven full time ( with VC and non VC ) 80 series Vs .. my factory part time 80 .. I will keep my HF1A t-case .. maybe it's the kind of driving of road that we have .. but I can't see and advantage for full time for me . .
Mine came with part-time as well and I am fond of the way it drives and handles. It actually is entertaining to drive.
But I've never been driven the awd counterpart...
I had a broken front axle/birfield joint, locked up the center diff and drove it for a year and a half in two whell drive. I loved the way it handled and drove. The front end was a lot lighter, but it made cornering easier, and the cruiser was way more responsive all around. More acceleration, power, less hum. And I got about 1 mile a gallon more.
I am definitly doing this conversion on my 92 when I can afford the kit and time to do this. The cruiser is my DD work vehicle, so this would pay for itself much quicker than most. My engine is the 3FE, which may make a difference in the MPG change I see when in two whell drive, and the changes others with the larger newer land cruiser engines see.
I think the conversion for me is a lot easier though, since i have no VC, but not sure. Does any one know?
It's an easy test, drop the shaft, lock the center and drive to see if you like it. I have driven mine front and rear drive, I prefer AWD.
