Full time 4wd
Va
ok I’m sure this has been covered but I couldn’t find what I was looking for. When you have the front axle on jack stands (wheels off the ground) of a full time 4wd lc should (in high range) you be able to free spin the front wheels? Or if you have one wheel off the ground should that wheel be able to spin. The “full time “ stuff I ve messed with in the past needed a slip for the front wheels to engage.
So I should be able to spin the front wheels by hand while the rear is still on the ground?
Spinning the front driveshaft? No. Front wheels? In opposite directions
Works just like the rear end. Except it's in front.
if your front diff is not locked, and the driveshafts are not removed and the rear wheels are on the ground and the transfer case is not in nuetral, and you have both drive flanges installed or if you have locking hubs and have both installed and in the locked position (like flanges), then turning one front wheel in one direction will cause the other front wheel to turn in the opposite direction.
Awesome thanks
When you have the front axle on jack stands... ...if you have one wheel off the ground should that wheel be able to spin.
Yes. The 80 system allows for one driveshaft to move when the other is not moving. There is a differential and a locker in the transfer case, when the locker is engaged both driveshafts are locked together and the above scenario is not possible.
Not if the t case is in gear and trans is in park
True. I didn't consider the trans. Been hitting the sauce a bit hard tonight. :cheers:
If you’ve ever been to Bangkok you’d know that the first thing you check is the trans. Just ask @UltraFJ40
