Fuel tank
Thanks a lot, GA Architect! I found that piece in the boxes of parts. :bounce:
img_3211-jpg.1158580
img_3208-jpg.1158579
[/QUOTE]
I’m gonna resurrect an old thread. I’m having trouble with my fuel lines.
Can someone confirm this for me:
On a 1978, the fuel return line comes out of the top middle of the tank, and the fuel lick up comes out of the bottom outside of the tank, on the driver’s side of the tank?
Yes, that is how I just plumbed mine in also, the lower one on the bottom goes to the lowest portion of the tank, that is the fuel pick up. I capped the other one off that is in the center drivers side of the tank, I don’t have a return line. Mine didn’t have one in the top middle of the tank.
Are you using a OEM steel tank or the aftermarket poly tank?
CCOT is missing the semi opaque white cylindrical item that is in GA Architect's truck before the charcoal can. I have it too on my '75 USA 40. What is it?
Check valve
Oem
Here is the fuel pick up line.
I sure hope.
That is how I plumbed mine in.
Weird. I do not recall seeing that line on my tank. I’ll have to check it out today.
Thanks for the pics, @rkymtnflyfisher
Yes, the hidden underneath line is the fuel feed on later tanks equipped with feed & return. It's confusing because early tanks without return use the fitting in the driver's side as fuel feed, then it becomes fuel return on later tanks.
Yup, confusing indeed.
Anybody painting these new tanks with anything before install? I ordered a new OEM tank and the paint is not great looking out of the box. Not looking forward to it getting scratched up and rusting out again.
I just coated mine, and everything surrounding, with Boeshield (paraffin wax). I figure that I will pull the seat and the tank from time to time to do a cleaning and waxing. Be sure that the tank is not sitting directly on the truck body, but rather, padding. The nature of the drain plug's underside access is going to allow abrasives in and create a vulnerability.
No, the hole under the tank is open, The drain plug kinda hangs down through the hole. Also, I'm not sure if it's intentional, but the design of the ribs stamped in the floor will get most of a gas tank leak to run out the hole, instead of forming a couple gallons puddle inside the cabin.
