Fuel tank question
Southern Maine
Anybody ever changed out the connector pipe fitting in the fuel tank? That's the part where the hoses attach. The new part is apparently available and mine may be leaking slightly so I'm contemplating trying to change it out. I can't tell from the part diagram if there is a gasket under it or even how it is attached to the tank, mine is so rusty and hard to get at that I just can't tell without starting the dis-assembly. I'd replace the whole tank as a unit but hazmat shipping from someplace without road salt to up here in the rust belt costs twice as much as the tank.
Just trying to get some info before downing the truck for however long it takes, this is my DD and I'd hate to have to sideline it for more than a weekend.
Thanks for any info!
Won't be haz mat shipping on a used tank cause it won't be full of fuel.
Yes, the fill pipe nozzle is removable and there IS a gasket under the cover plate. I've been doing the same researche cause my taank sprung a leak, but I think mine is the crack at the front...
Unfortunately you will find that the fuel vapors from a used tank does in fact require hazmat shipping, or at least that was what I was told by several trucking companies. Sure it's a crock, but what can you do? Besides drive there and pick it up yourself I mean...
It looks like some tanks go at the seam, and others crack at the bend where the brake cable goes across. Mine seems wet around the connector pipe and I can't tell if it's from the hoses or the part itself. I replaced the small hose with a hardware store piece while the correct one is being shipped, but I can still smell the fuel. I really hope I don't have to drop the tank and work on it but it looks like that may have to happen.:oops:
Mine recently sprung a leak at the end in the top of the channel too. If so many people are having this issue, you would think we could get toyota to replace our tanks.
