Fuel Tank Location
Big Island Hawaii
Would a fuel tank in the cab (older style) be more protected from trail damage than the tank under the cab (newer style)? Or would it make a differance?
Are there yank procters avilable for the under cab tanks?
I have not seen a under cab tank, so I was wondering if that style would be more vulnerable to trail damage.
Allen
Cruiser88,
I was thinking of the differance between an earlier 79 model as compared to the late 79 model.
Where the stock factory tank is in the cab and the front seats sit sorta on the tank as oposed to the later model where the tank is mounted under the cab.
If that makes sense.
the later tanks are tucked up inside the frame pretty tight, plus a skidplate.
it sits no lower than the bottom of the frame, plus you get a few more gallons!
Allen
What year is your LC? IMO, under the pass seat is the best location. Or, you could use the old Conn-Ferr aux. style that mounts in the rear or even run a fuel cell in the rear tub if storage is no concern to you. The '79+ 40's tank location is high enough & protected so I wouldn't worry about that.
