fuel sender cluster pin
hi im trying to locate my fuel sender input wire to the cluster to install a haltech fuel signal conditioner.
from what i can see in the fsm its on connector C13 but isnt to clear witch pin.
a search here resulted in someone saying connector C15 (witch i assumes a mistake for C13) pin 6.any help would be greatly appreciated.
regards Dale
Helpful? This doesn’t go to 13?
regards Dale
By "cluster" I think you mean combination meter or dash cluster?
If so, then the fuel sender hits connector C13-pin 14, according to the 1994 EWD, which you can download yourself from the "resources" section above.
i downloaded it just had trouble reading it and wanted to be sure, i pulled the fuel pump plug and checked ohms
