Fuel Return Line Restrictor??
USA
I've got a '77 non-US with a '78 carb (also non-US). I've been using Pinhead's excellent videos to rebuild the carb (it's going swimmingly - the stuff is in the dip as I type). My carb is the return-type, with a line running to the gas tank. Upon taking the bolt that attaches the return to the carb apart (the factory banjo/bolt is long gone), it's just a fuel line connector (M12 x 1.25, I think) with... wait for it... a little longer.... a STICK jammed inside of it... to, I assume, serve as the restrictor. What parts do I need to buy and where, if anywhere, can I buy them to return the return (zing) to factory setup? I do Not want to eliminate the return. Does Toyota still sell the stuff I need, and if so/not, anyone got part numbers? @Pin_Head you just know I'm hoping you're reading...
TIA!
Classic cruisers in Poncha Springs CO has a ton of used carbs. Might wanna call them.
Am I right in assuming there was some kind of restrictor in the factory banjo setup? That is, I can’t just buy a new metric fitting and hook it up to the return line, right? Any aftermarket solutions?
And ceylon, thanks. I’ll check them out - just wanting to make sure I’m not missing a simple solution.
Yes, in 1978 there is a small silicon check valve/pressure regulator inside the M12 banjo bolt.
If there is no restrictor, then 100% of the fuel is returned to the gas tank.
Thanks Jim. Now, if I cap it, I would need a 79+ pump?
That would be best, but it will operate without a return. The advantage to a return system is that cool fuel is constantly being pumped to the carb, then dumped back into the tank to cool off.
