Fuel pump
Deathvalleypaul
FJ80 Collector
Near Pasadena CA
what is correct Denso fuel pump for 1994
Thanks for your response,
That pump by Denso the 951-0003 is nowhere near the fit of the original. Electrical connection is different, and fittings are different and it is an inch shorter. My old pump is the same number Denso, but a different pump. That is why I posted up. My old pump matched the factory pump in my 94.
Rockauto lists these part numbers
9510003
9500107 (kit with strainer)
9500109 (kit with strainer)
Sparkplug dot com also lists the part as 951-0003
OEM part appears to be 23221-66040 for 1993-1997
Wrong pump in the box??
Contact Denso customer service??
Not the wrong pump in the right box either. All of the pictured pumps show a different pump than the last two I used. I am going to pull a pump out of one of my parts cars for a reality check. Denso customer service put me on hold for 40 minutes yesterday and I gave up but I will retry again. THANK you for your response on this. Maybe I have been running the wrong pump and pickup assembly since I got it several years ago.
Photos of the old pump and bracket might help with ID'ing the current parts??
FWIW
Interesting that both parts ( 23221-66040, 23221-46060) appear to fit,
is one a superceded part number?
That is, considering the fuel pump pressure is the same.
