Thank you for this schematic and the AFM detail. I'll check it out and report back.Did you check for continuity at the AFM? The flapper door has to move to enable power to the fuel pump (lower left...)
I couldn't agree more. I have this on my google drive set to access offline so it synchs to my phone, tablet, computer... etc.... It's the only way especially if you need it when out of cell range.And download your FSM!!! And save it to your computer, your Google drive, your moms computer, burn it to a cd and put it on a shelf. It’s a must have
Thanks for the diagram. will check it out.I'd second getting the manuals. This is for OBD1, not sure what year your truck is..... View attachment 3271213
Gracias and perfect timing for weekend troubleshooting.All '93-'97 Land Cruisers have the "DLC 1" port at the firewall; the OBDII port is "DLC 3" on the EWD (I've yet to find DLC 2). The FSM troubleshooting instructions still recommend the DLC 1 port for some functions on the OBDII models.
My JAN'95 doesn't have it either (or the Gen terminal, so I can't check ECU rpm input). Sucks to be us.
I attached the '95 Fuel pump relay and resistor checks. There isn't a similar, simple, ECU/system check as with the OBDI models on the OBDII models.
I attached the very long, laborious system check procedure for you.
