Fuel line?
Fargo
This gas line appears to head back to the gas tank. Any idea what/where this goes?
That's not the fuel line. I believe it is one of the lines for the charcoal canister, which is missing. It should go to a black plastic unit that's behind the metal fuel filler shield on the inside, near the b pillar. A plumbing diagram can be found on the ccot website.
Thanks, you are exactly right. Goes back to that black container then everything is cut and capped off. Is this something should get hooked back up asap?
In my experience, those braids are often covering cracked rubber hoses underneath. My cabin stunk with fuel until I replaced all of those lines with new ones. Really simple and cheap fix.
Any advice on where I should look for a charcoal canister? I have a F155 engine. Not sure if that makes a difference.
I have seen this one mentioned, but not sure if it works with my situation.
Thanks
I have several stock canisters for your year in stock if you’re interested. 818-953-9230 to follow up
