Fuel injector servicing
My 2008 is getting up there in years and mileage (200k) and I was hoping to hear opinions on fuel injector service. It seems unlikely that at this age they would not benefit from some form of attention, but not sure if a heavy flush or replacement is the right way to go.
Trucks runs fine though mileage and power are what I remember from years past.
Thanks!
I feel like the dude who cooked a HG and replaced the entire top end recently went through this.
For cleaning I would recommend sending them out. RC Injection in Torrance has really quick turn around and do great work.
You can also buy new ones, they aren’t super expensive.
If you used Top Tier gas there is no need to worry about it.
If not or you want to sleep better do some Chevron Techron treatment. Unlike some products on the market it actually works, independently tested, not a snake oil.
I almost exclusively use TT fuel and my injectors definitely needed cleaning by the time I got it done around 235k.
Snippet of the below thread:
I did notice one bank's LTFT's were +7% a few months ago and had planned to do the injectors at some point. The head gasket forced my hand. When I pulled them I didn't keep track of their prior positions, but upon return they are all numbered.
Optimal flow from these is 350cc. At 235k miles they ranged from 342 down to 283, with an average of about 317. Additionally the spray patterns were not great, mostly scoring "fair" but some even dripping. After cleaning all eight ranged from 349 to 351 with excellent patterns.
I wonder if there was something else at play that degraded your injectors performance.
My other Toyota is close to 300k and never had an injector related issue and it is not a premium gas queen like the LX.
These are na engines so they should not need regular cleaning like the forced ones.
your cleaning data is interesting. i thought the stock tan injectors were 372cc, your data shows 350cc.
I'll admit to not knowing a lot about our injector specs but have to assume RC does. And the fact that they all went right to 350 after cleaning suggests that's where they are supposed to be. A quick search online indicates tan injectors are also 480cc for non-FFV engines.
Could be the difference is dependent upon a change in pressure? Not sure if there are universal standards for this.. I will say the truck runs like a top now. Definitely a smoother/quieter idle than before. I haven't dug into LTFTs yet..
Not directly applicable to the 200, but I had the injectors in my 80 serviced and it was worthwhile. They clean and balance them and provide a report on the test results. They also provide replacement o-rings and injector seals. My rubber bits had vacuum leaks, and this resolved that issue. It was also very affordable relative to replacement.
ya or just minor testing variances? who knows..
Only reason I got curious was because I recently swapped mine to the green TRD injectors (because supercharged...haha) and went down the rabbit hole of trying to find out what the stock was.
"Toyota's manual for 3UR equipped vehicles spec a range of 83-99 cc per 15 seconds (332 cc/min to 396 cc/min) - the center of that range would be 364 cc/min.."
At 160k all were spraying perfectly on my Lx. What I did see was the o-rings were a little degraded but not failing, the upper rubber gasket on each was hardened and bad in all cases.
At 200k+ I would rebuild these for sure. I did some matching and that turned out harder than I had hoped with my bench. RC is famous for doing that sort of work and next time I would just use them for R&R. One reason for that is that there are some very tiny filters in each injector that I couldn't source.
It is an easy job, but I did struggle with the passenger side fuel line connector and the rail mount. I used Lisle 39210 Main Fuel Line Disconnect for Toyota and for Nissan drilled with a length of fishing line.
Screenshot 2026-08-18 at 11-14-22 Mahle Original Fuel Injector O-Ring GS33579 AutoZone.webp
ya the rear passenger side is tricky. my mechanic helped me with swapping the injectors and he ended up just doing it with the rail still connected..
