fuel gauge working - don't trust previous work
CT
The fuel gauge on my blue and white 55 has not worked since I purchased it 2 years ago. I tried tracking down the problem a couple of times without any luck.
I gave it another shot and looked at the wiring diagram again. Yellow wire with red stripe goes all the way to the gauge. No trouble finding the wire at the sending unit, looked at the wire going into the harness. I cut away some of the tape that was there and found that the yellow and red wire was plugged into a red and blue wire connector.
Looked around and found the yellow and red connector that was not being used. Plugged it in and the gauge now works.
I guess we should all know by now that work previously done on many 55's may not have been done correctly. I assumed the wire going into the harness was correct because the harness was wrapped very professionally with black tape. I'll try not to make that assumption again.
It's good the have a fuel gauge again.
nice feeling when you find things like that. really makes you wonder what else might be wrong that you haven't found yet
I guess when you work on 30 year old trucks, it's always a work in progress.
Add wheeling into the picture and there is always something that needs doing.
It seems PO's and wiring mysteries run hand in hand. The damn hippies that had my little piggie did some very interesting/peculiar things. When I get back home later this week, I will post the latest and greatest damn hippie PO murder (psuedo wiring related) I found on my truck. Boggles the mind.....
