Fuel gauge issue
Philipsburg PA
My fuel gauge stopped working.it's stuck at half full, but the fuel light works. I'm wondering what I have to do to fix it. Should I just replace the pump and sending unit or could it be something else? I don't know how the fuel gauge works. If it's just a float or I don't know. If it's the float how is my fuel light working?
@bigredmachine
I'm going to fill the tank on Tuesday to see what happenes. My thought was to not fill it because if something is wrong now I have a full tank of fuel and I only drive about 12miles per week. But I'm going to fill it and see if it knocks the float around.
The fuel sending unit has a float and a sensor for low level. Sounds like the float is stuck but the low level sensor is working. Remove and inspect operation of the float would be my recommendation. If rusted or need of replacement, here's one:
TOYOTA OEM 1991-97 LAND CRUISER Fuel Gauge Float Sending Unit 8332069055 | eBay
Thank you for your response and link. I'm always thinking that I want to replace everything in the tank before it fails and for a piece of mind. I was just hoping it wasn't a gauge problem or something.
if you want you can take the pump and sender out of the tank inside the truck, the access hole is under the middle row seats and you will need to remove both of then. if you decide to do that make sure that you get a new gasket for the sender and new bolts for when you reinstall.
if you decide to take the tank out instead the drive shaft needs to be unbolted from the rear diff and moved out of the way. and its a 2 man job just because the tank is fairly awkward to handle without an extra set of hands or something else to hold one end while working
@bigredmachine
Thank you for the info. It will be worth pulling my drawer system out just to not drop the tank. I did not know about the access whole, but I should have figured toyota would do something like that. Is there any reason I shouldn't go thru the top ports?
@bigredmachine
if the bolts are very rusty you may need to tap the socket on to the bolt and the access may be a pain to tap the socket on. their 8mm bolts by the way and the banjo bolt for the fuel line is a 17.
taking the tank out isn't bad but if you think that's going to even be a remote possibility start to spray up the strap bolts with rust penetrant. I had to take my tank out a few times because it rusted through and was "fixed" the first and had to be sent out again
I have access to a lift, but I'll probably attempt the access whole. Also considering the tank will be almost full. Ugh. Its just not what I planned on doing. I might hold off for a bit once I get the fuel pump.
@bigredmachine
If your light works you are fine. My gauge has been stuck at full for 5 years now. I just reset my trip meter every time I fill up. I know how many miles a full tank gets me and my warning light still works.
Getting to the sender and float is easy as others posted.
If it recently worked use the half tank of fuel to jostle the float by a few quick stops and starts, has worked for me!
Not meaning to hijack, but I have similar problem here. It only goes to about 2/3 then eventually seems to work once it gets below half. The light still works. My problem is it coincides with a drop in MPG. I suddenly went from 14 MPG to 10. Caught me a little off guard.
So, the process is to order the gasket and replacement bolts, pull the float, clean it all up, and reinstall then hope for the best? Is that right? I'd be going in through the access hole as well.
This is exactly what I'm going to do. Probably in a few weeks. And I know it's has nothing to do with it, but I also noticed a drop in fuel mileage. I think it's the winter gas around here though.
Pull the pump, replace sock, and top gasket. If everything looks good in there follow the wires from the plug on the top of the sender. You will see that they go towards the DS rocker. If you crawl under the truck you can see where that harness plugs into another harness, sometimes one of the wires will break right there and it will mess up your signal. I had this happen to me and detailed the fix with a few pictures in my Moby Dick thread.
@half k cruiser
I will check the wire harness first. I have been doing A lot of off roading and winter trail riding lately. Hopefully the plug is just boogered. Thanks.
Hopefully not, they aren't the easiest thing to repair just do to the limited access. It can be done though !
The windings on the fuel level sender break as the sweeper moves across it, I found when filling tank the gauge worked intermittently.
As per above, pull the centre seats, pull back carpet, remove oval plate, remove sender bolts withdraw, usual precautions battery disconnected etc.
The low level light is controlled by a sensor on a fixed length rod, the level sensor is the typical arm/float, this allows you to bend the wire arm to suit the amount of fuel you have, thus you can calibrate it against the gauge if you feel inclined?
regards
Dave
