Fuel delivery issues
Idaho
Hi all--
So recently, my in-line electric fuel pump died on my '87 60. Replaced it. Ran fine for a few days, then it stopped idling. Replaced the fuel filter, and it ran a little better, but not much and the idling issue was still present. This past week, it has run pretty well: very little chugging but still would only idle maybe 10% of the time. Yesterday, I filled the tank and it ran like crap. Serious lunging and chugging, and in order to get home, I had to run it on full choke in 3rd gear, and even then it was dicey. This is the second time that this has happened after filling the tank (from different gas stations). I thought it might be a vacuum issue. Now I'm wondering if it's a fuel sending unit issue? Any ideas?
Why are you running an inline electric pump and not just a good mechanical one?
If we are talking about a Carburated engine then there should be no need for an electric fuel pump. Put a new OEM Toyota mechanical pump in and get rid of any electric pumps that might have been added. Make sure your delivering and return lines are in good shape.
You have a fuel gage sender but it just measures fuel height and doesn't supply fuel like in a fuel injected truck. The stock 60 has a port near the bottom of the tank where fuel is drawn from. ***so if your tank is full of rust the draw tube could be clogged....but I'd expect you'd see a dirty filter***
Guessing you have a carb issue. When the truck stalls can you see the fuel level through the sight glass in the side of the carb?
An FJ60 tank. Fuel supply and return at bottom of photo....hole further back is for fuel gage sending unit.
You have a fuel gage sender but it just measures fuel height and doesn't supply fuel like in a fuel injected truck. The stock 60 has a port near the bottom of the tank where fuel is drawn from. Its likely you have a clogged carb problem.
Thanks. I'm relatively new to this. PO had the electric pump, so I think I will go back the OEM mechanical pump. Good advice. Besides, the electric pump is so loud, it drives me crazy. Will see about the carb. Thanks!
When I got my truck someone had added an inline pump as well. I couldn't figure out why it was added because I still had the mechanical pump. I removed the pump and its wiring and if anything the truck ran better. My theory is that the truck was having hot start issues and someone who doesn't know FJ60's put the pump in as an attempted solution....when in fact the proper repair would have been to fix the carb cooling fan.
You might check with Cruiser Outfitters @cruiseroutfit
I think that was the case with mine. It still has the mechanical pump and "looks" like it's in fairly good condition. But when my electric pump died, it wouldn't start at all. So, newbie that I am, I replaced it.
Fuel level was about half-way up the site glass when it stalled.
How is the condition of your spark plugs, cap, rotor, and wires? Have you done the air filter recently? Have you ever checked the valve clearance?
Going back to the stock fuel pump is a good idea, as was the fuel filter.
You could also try pulling the two bolts circled below, and blasting some carb cleaner up in there to try and clean in and around the jets. It's not an ideal angle to get a spray nozzle in there but I have had success when dealing with a similar fuel delivery issue. Note that fuel will definitely spill out when you remove those two, so be prepared.
Replaced the air filter. Plugs, wires, cap, and rotor have less than 2k miles. Have never checked the valve clearance. Wouldn't know where to begin with that. Sounds way outside my limited skillset. Will try some carb cleaner in those jets. Thank you!
Valve clearance sounds like a big bad complicated thing but its really pretty easy.
Here is a good write up on the procedure.
This is a great time to replace the valve cover gasket too. The basics of it is you have intake and exhaust valves and you use feeler gages to measure the gape between the rocker arm and then top of the valve. Its a 6 cylinder engine, 2 valves per cylinder so 6 intake and 6 exhaust valves. The intake valves have a difference clearance than the exhaust.
Okay, that sounds more approachable than what I was thinking! Thanks! Just double checked my plugs and they are clean. So I may just try checking the valve clearance. Thanks again.
I suspect your valves are not the issue and you've either got some crud in your carb or the other common problem in these trucks are vacuum leaks. But if you've never checked the valve clearance and don't know when they were last done it wont hurt to do it. I picked my truck up, drove it 2000 miles home, had it here for a few months and finally checked the valves and replaced the valve cover gasket. I had valves that were .010" out of spec...luckily to the loose side (too much gap)...but it started and a ran a lot better after I adjusted them.
I've currently got the whole intake and exhaust off the truck because it had exhaust leaks and a lot of stalling issues due to bad gaskets.
Also...do you have the OEM fuel cap on your filler neck? And when you open the cap do you get a big whoosh of air?
Hi all--
i would simply suggest replacing your OEM fuel filter & then also re-hooking up with a NEW OEM Mechanical fuel pump
all new hoses to the filter and NEW hose clamps too ALL new
i have dealt with more then one fuel suction issue on a 2F equiped land cruiser too , thus behind your pump back to the tank suction tubes outlined above in the nice tank oem photos @Seth S took time to post for everyone
here is a OEM fuel filter
and
a correct OEM mechanical pump i offer ..
please let me know if i can help in any way ....:)
and
Thanks. I am now in the process of ditching the electric fuel pump and reverting back to the OEM mechanical pump. Will let you know how it goes! Thanks for the advice. I'm fairly new to this!
Hi, Years ago it was extremely common to add electric fuel pumps on the frame next to the tank. Just one of those things back then. Use some ethonol free gas and carburetor cleaner ,maybe a couple of cans. Have someone in the drivers seat holding the gas pedal down while you spray the cleaner . Do not get your face to close! Put ethanol free gas in the tank. Mike
Thanks! Will give it a shot.
