More specifically
This Bracket:
http://www.gigaparts.com/store.php?action=profile&sku=ZDM-K400CNMO
or this Bracket
Depends on what antenna you have.
HRO directed me to NMO.Follow along with the video below to see how to install our site as a web app on your home screen.
More specifically
This Bracket:
or this Bracket
HRO directed me to NMO.This is what I am currently looking at. Read some reviews on antennas across the INTERNET. Mount the radio in the rear on top of my safari drawers and then run the cheap cables I just bought on Eba (Thanks James) to the front.
FT-R -- Yeas FT-R M/CM Dual Band FM Transceiver. Wide Receive of 108-MHz and 700-MHz (Cell Blocked). NOAA Weather Alert. Illuminated keypad & microphone.
GIACOMO -- NM Deluxe mount. w/6.5' REG-316 Teflon coax & PL.
SB-NM -- Comet M/Cm Mobile Antenna (Black), 3.0/5.5 Gain, 38" Length, NM Connector
better pass the test on Saturday![]()
How are the practice tests coming? I expect I'll see you Saturday. I'm going to test for General.
I mounted the unit in the cubby. It's out of the way and not dirty. My panels behind the plastic all get alot of dust in there except here.
The antenna cable was 6' long and it just is enough for this spot. If it's further away, you will need a 10'+
Ken,
Is Rising Sun planning some type of list of the HAMS at CM?
-B-
Just curious: do you run with the cover back on the cubby, or do you leave it off? I'd like to install the rear of my new 7800 in the same spot -- just wondering if it gets too hot with the cover on?
5. Is the speaker still working when it's installed in the cubby with door on or can you disable it?
6. Where is the best place to mount that cheap radio shack speaker--do you have the model number?
