The one thing I WOULDN'T do is spend $ on getting a vac retard dizzy.
If you want a cheap solution, you will ultimately get a cheap solution.
I will double check 153624Spark plug wires on the right cylinders, two could be crossed? Sounds dumb but it happens...
Ok what is your timing set at. When I first checked the timing I know it was set pretty far advancedI am going to say this knowing I am going to get some negative feedback......I set my 77 desmogged 2F (thole dizzy/carb) as per the WSM and it felt very underpowered. Only when I cranked the timing up did it seem to make a difference. I cant tell you what the timing is currently set at but it is pretty advanced. Good idle, good acceleration (for a 40), no pinging, etc.
Can I get some info on a carb and dizzy from you. Prices etc.It doesn't work that way because of the type of shaft the oil pump uses. Makes it walk really side to side. Plus the counter weights come on at different RPMS. Thus it is really unpredictable as to what it will do.
I will try that. I was driving it yesterday and noticed that when I am in first taking off from a stop or when I switch gears and the Rpms are low is when it lacks power bad but if I pull the choke it helps big time then when I get the rmps up push the choke in. Kinda tells me it's something in the carburetorI really dont know as the flywheel lacks marks. My flywheel looked like the BB and the TDC mark had been machined off. I marked what I thought was the bb based on TDC of the motor. I could see what I thought was the remnant of the BB. Seat of the pants adjustment. I made certain it wouldn't "ping" under load with 87 octane fuel. All I can say is that mine did not run well set on what I determined to be the BB. Yours very well may be different! I had to rely on the butt dyno rather than the numbers.
