Frozen Oil Filter Help
Up 4
So what has started as a quick oil change has turned into a major pain in my rear. I have a SBC in my '71 cruiser and my oil filter is frozen onto the motor. I tried a strap wrench and all that did was crush the filter and eventually put a hole in it. Tried the screwdriver through the filter and it just tore the filter apart.
I can see the top metal plate where the filter threads onto the motor (with little holes) and have been trying to loosen it by banging on it counterclockwise with a screwdriver/hammer. I hit it with PB Blaster and have walked away from it for now.
Obviously space is very tight with the exhaust and clutch right there. . .
Any ideas would be GREATLY appreciated. . .
Thanks
did you try warming up the motor and then try it? I know heat can help. but i guess the exhaust might be to close.
You say space is tight but if you can get a lare pair of slip lock pliers in there you might be able to break it free. Stuck oil filters SUCK! I once drained the oil on my Jetta but could not get the filter off. Right after I twisted the case with my strap wrench and just prior to punching it withteh screwdriver I put the new oil back in and took it down to Walmart and had them change it. for you it is too late for that though...:o
The motor was around 140 when I began working on it and I can't reheat it now:rolleyes:
I'll keep at it with a chisle/screwdriver and hammer. I'm also thinking I might be able to get a pair of snap-ring pliers into the upper holes on the filter.
If your able to see the threads, spray penetrating oil ( I use Zepreserve) on them and let it sit overnight...works everytime...good luck
