front winch bumper mounts?
It's more than likely that you will be able to mount a towbar setup on the recovery points. We curretly haven't tested it or done any fittings as of yet, but I've seen it done on other bumpers similar in design....Though most of the towbars were more modern fold down&in kinda outfits vs the classic fold up design.
CruisinGA said:
FJ40's shouldn't have anything other than a 28" section of C-channel or box tube on the front... all that angular space agey lookin @&@&@&@& just screws the looks and approach.
IMHO
You'd be ahead to focus on 60's/80's and 100's. As a demographic, those owners are much more prone to buy bolt-on bumpers.
Your definetly right about the 60's/80's and the new model crew, as fare as there being a greater market for those, though those models spacifically creat more of a challange due to the popularity of ARB bumpers. but designing for those has started.
I can see your view on not likeing the "space age" look, though that wasn't really what I was thinking when I designed them. It was more of a desire to maximize function and still maintain some sort of style... Infact the approch was and still is a main focus for all my bumper designs, hopfully if all goes right it won't take away anything from the aproch, and in some cased increase it.
thanks for the feadback though.... its definetly appreciated.
And please everyone keep it coming.
jfonz said:
originally from the factory thease componets were rivited on, so removal would require cutting off, or drilling out the rivits. this job would be much easyer of course with a torch of some sort, but overall it shouldn't be that difficult with the right tools.
Anyone that has tried to remove the factory rivets knows that it is no fun job. I have done it w/ a hammer, chisel and a drill as well as with a torch tip and it is NEVER fun.
You would be better off using the factory mounts (if you can find any that are still straight). Which is exactly why most people make their own 40 bumpers.
True. The main reason we have been including the 40 in the design process is because of feadback from cruiser owners in the local are. Over the years I have also found that there are those out there that will take a bumper designed for a different rig (for example an ARB YJ bumper installed on a 40) and modify it to fit there rig.
Like you said most people just make there own, not only becuase its easer to make the holes match up, but also because its alot more inexpensive when it comes down to a dollar vs dollar amount (labor and time not include). But there are those out there that are willing to spend the money....
I quess another question is, If removal of the mount things is a little to much, would trimming them be less of a pain?...Enough so that it would make it a little more worth it?
I've found that rivets are pretty easy to remove with 2 tools.
Grind the head down flat, and then use a punch and hammer (or air hammer) and beat it through.
The best option would likely be to use the factory mounts, but have provisions for the people whoe's mounts are long gone, (mine were).
