Front shock nuts
Ca
The original front upper shock nuts are seized it seems on my 94 80 . They aren't reverse thread or something stupid like that are they? Im thinking of just sawzalling the passenger side off but have no idea what to do about the drivers side.
I couldn't find any info on similar situations. Any input would be appreciated before I go medieval.
When I changed mine a few months back my research suggested that a nut splitter was the last resort if you can't get the drivers side moving. When i did mine i used my own home brew antiseize and an impact wrench with a few different extensions and a u-joint. Popped right off.
Hit passenger side with a impact. Top driver's side I used a air die grinder with a half burnt down 3inch cutoff wheel. Just barley fit in there. Could use water pump plyers on the upper shock tube/shaft to hold it.
If you don’t want the shocks anymore then grab the shock body with a big wrench, with impact it should come off easy.
There is no real way to get an impact on the top drivers side mount unless you have lots of flex joints, and even then idk if it could be done short of taking the master cylinder off.
