Front seat disassembly
Central Virginia
How difficult is it to just swap out the seat back of a driver's seat, keeping everything else the same? And what about the motor that drives the seat forward and backwards on the tracks?
Here's my situation: trashed front seats for my '98 LC (classic) with flattened padding that I didn't want to pay for reuphostery. My project time has been very limited recently so I haven't wanted to sink too much time just into the seats. But, I found a pair of front seats in a junkyard from a '99 LX470. Passengers side is in good condition and swapped in with no problem. Driver's seat - bottom cushion leather is torn but the seat back and armrest material are pretty good, and padding is better all around.
When I put on the new seat cover and mounted the "new" seat, I found the motor is not driving both sides of the track forward and backward. Only the left side track moves along, and the right side doesn't move, so it twists and binds up on itself. First looked to see about just the replacing the motor, but that's looking like quite a bit of disassembly.
If I could just swap the "new" seat back onto the "old" seat, I would be ok with that, although the other one would be nicer. I don't know if it's worth trying to swap the motor. But I'm wrapping up for this evening and not going to try tearing into that right now either way. Wanted to ask if anyone has tried this before for the next bit of free time I have to work on it!
Well, may be answering my own question. Found a video on seat upholstery that is giving me the info I need to know. Won't finish tonight but on the right track (pun intended).
Is it possible to swap seat bottoms from passenger to driver side? Seems like it’d be a great way to add more life to each outer edge bolster.
There's a chance the motor isn't dead.... just stuck in a particular spot from not moving for so long. I would try and connect power and "help" the motor/gear mechanism back and forth (not while it's mounted).
No
No, that won't work. The outer bolsters are LH/RH formed.
Not to argue, but just having done this, there's a lot more to it than that.
And I agree, even though it's expensive, factory foam is the way to go.
just bite the bullet and spend the $ on new leather covers, its so worth it. That and the steering wheel are the parts you touch 100% of the time you are using the truck. I am so glad I did mine (LSEATS) even the cheap leather replacements are worlds better looking, smelling, and feeling than 25 year old shredded disintegrating crap
