I just finished replacing my front locker with an auto locker. years back i put one in my jeep and it works great. I was testing it out going around the block (if it goes bad i'm close to home!) I know normal operation on pavement would be realllly bad but for testing purposes i was looking for normal straight drive operation and typically it should fight a little if i try to turn.
I got out, engaged my hub lockers, put it in 4 hi, started driving and it yanked my steering wheel hard right. driving only a few feet forward slowly got it stuck all the way right. i couldn't muscle it straight. if i backed up it would straighten out but continuing to back up never switched to turning left, it just stayed straight. start moving forward and bam, tight right again.
heres the next problem. I dissengaged the hub lockers, but i coudn't get it out of 4. I could put it in N or 4HI, but it wouldn't shift back into 2Hi. I went back and forth and after a few times something finally released. i had my stearing back, and i could shift to 2HI again.
I popped it back on jack stands and verrified the wheels turn the same rate and pressure is matched. verified the wheels can turn seperate w/out throttle (the lovely click sound).
any ideas? not sure what to check next.
