Front Locker Harness Pins
South Central PA
97 Land Cruiser ...
So sometime in early 2020, before everything went crazy, I managed to rip the entire sub harness off the front locker and all the way up to where it connects near the fender and firewall. I took it to Toyota expecting them to make a patch harness, but in their infinite wisdom they decided to hard wire the locker onto the truck. I then proceeded to swamp said truck in a mudhole and managed to destroy the front locker. Onur helped me get the proper pieces to make a factory connection (splices and plugs) and I bought a new locker, did the splices and now it doesn't work ... UGH.
I took it to a local shop, since OTRAMM and Tabasco are backed up with projects right now. We can and have confirmed pin out on the actuator side, but the tech is asking if I can help to confirm pins and wire colors on the harness side. I've read through many locker threads, but the harness pins and wire colors are not clear. The harness side has continuity (per the tech) and he says that he can hear the actuator hum like it's getting power when the switch is turned, but it does not move.
If anyone has easy access to that area or is in the middle of messing with the front locker, could you please post pics of how the wires are oriented in the connector on the harness side. Basically what color wire goes where?
When I was bench testing my front locker on the 3rd member from my HDJ-81 the FSM pin-out seemed wrong. Flipped somehow, and never did figure out the arm angle setup instructions. Went without as a result.
