Front Hub Grease Every Time?
When removing the front hub assembly say to replace the rotor is it necessary to re-pack and re-grease everything? Or can one just add enough grease similar to the amount that was wiped away when removing the nuts/washers and re-assemble?
Yeah, I understand. Mine looks like it could use a refresh for sure. Due to time restraints I'm hoping that just adding some will suffice for now. Its not a DD, but my parents use it when they're in town which is next week.
I'm going to do all the front end linkage bushings here soon so I'll tackle the full re-grease at that time.
Thanks guys
It's not best practice but I've gone the route of minimal cleaning and adding fresh grease without issue. If you know you'll be back anyway this is less of a problem.
Keep in mind that while the full clean out and inspect takes a lot longer you can easily scoop a lot of the grease/out off and replace it with fresh very easily. I'm talking 60 seconds with paper towels here. You can also wipe off a few bearing / race spots to inspect since most damage should show that way as it will often run all the way around the bearing / race. This is all pretty obvious but if you have the tub of grease sitting there along with a roll of paper towels and an empty box (for the greasy/used paper towels) you can accomplish a lot of the regrease job in very little time and strike an in between balance of sorts.
I'd also wipe/inspect any seals and the races that the seals run on to help them last and also go back together well. It's easy to disturb dirt/grit during disassembly and it can wind up in a destructive spot where it wears a seal out prematurely. A quick wipe and light greasing should only take a minute and should help everything go back together more easily.
If I had it torn apart that far I'd pull the bearings out, wipe off the bearing races to inspect, wipe the old grease off and repack. It only takes a few extra minutes if you aren't doing a total cleanout.
