How do they assure better flex?
I am going to try the front sway removal, as I used to run the SAS 4runner that way. Does anybody daily drive without the front sway? I'm not into the dissconnect thing to go wheeling.
from the SE page ..
Super flex radius arms are to suit 4 inch .
These are the most revolutionary design in suspension in many years, by simply bolting on these radius arms they will give you twice the flex over any other radius arm on the market for much the same price, even cheaper than some of the other brands.
The kit simply bolts on with an adapter plate on the passenger side and a standard drop radius arm on the Drivers side.
Tested in competion proving winning placings and with no on road problems these are the solution for anyone who is after maximum ground clearance with maximum flex.
Ask yourself Why not have more flex and the same driveabilty.
Very cool. Bolt on y-link. But these are not 80 compatible, correct?
I think the biggest thing being talked about here is balance between front and rear, regardless if with or without a swaybar, basically whatever it takes to make them work in unison, so when you drop off a ledge as mentioned above, instead of the front not moving down the ledge and supporting the vehicle, it drops the equivalent amount as the rear so the vehicle remains nice and flat as you descend. This can often be accomplished with softer springs and spacers, so the lift height stays the same but the coils flex better. Again, I haven't put my life on my LX yet to really know the dynamic of the truck...just speaking from past experience on 3rd gen 4runners. That's a primary case of the similar problem...front IFS and excellent flex in the rear overcompensating for the front's lack of flex.
Chris
yes they are .. those ones pictured are 80 series specific ..
I'm about to install the Slee 6" with their arms...are these SE ones going to be that much better, or just that much better over stock?
Chris
I wonder why only modify the arm on one side. It is very interesting, I'd like to see some pics of the results as driveability would seem largely unaffected.
The next issue is that most 80 lifts add longer pin mount shocks to account for lift, and this increases total shock travel when only the rear can use it. Walking Eagle for example has a 14" travel shock setup in the rear.
The 80 is in many ways too heavy to be on all coils (hence that rigid front end), and it presents major complications in balancing spring rate and offroad performance. Take a hard look at the FOR Gen II coils and you'll get an idea of how to make both work in the same coil along with a lightly valved shock.
I want to see a picture of an 80 descending an 8' ledge
I just put in a price inquiry to SE - with the AU$ exchange rates, this could be an interestingly priced option.
But, they have flex bushings in the arms. Doesn't that help?The SE ones are designed to improve flex - Slee are just longer than stock and correct the castor for the lift. They don't claim greater flex, and with stock bushings I doubt it would deliever any greater flex.
