Front end wobble
New Hampshire
1997 80 Series, I have been getting a front end wobble (severe at times) that happens mostly when going over bumps in the road or rapidly slowing down, it shakes the steering wheel and feels like the front wheels are wobbling a lot! I can stop it by steering side to side quickly. It doesn't happen on the highway or on smooth roads. I just replaced the steering damper with an OME damper, no change. I have noticed an intermittent clicking from the right front when turning, but it doesn't happen all the time.
Any suggestions?
Sounds like possibly worn/loose front wheel bearings. Jack up front end and try to wiggle wheel in the 12:00 and 6:00 axis. If there is any play your bearings need to be checked.
Clicking is low moly grease in the Birfields/ or worn Birfield that needs replacing. Are the balls at the end of the axle dry, wet, or dripping Birf soup?
When was last front axle service? If you don't know for sure, it is probably time.
Search on "front wheel bearings", "front axle service", "clicking Birfield".
Thanks, I'll try that, do Birfields need to be replaced completely or if that's the problem can you just replace the bad parts?
If you are lucky, it will just be low moly grease levels in the Birfield ball at the end of the axle. Level is checked through the square plug at top of axle ball next to the ABS sensor. Use a stiff zip tie as a dip stick and level should be 1/2 to 3/4 full of moly based grease.
Searching the terms I suggested will give you lots of detailed threads with great pictures to walk you through the process.
Grab the torque wrench, confirm that all arm, knuckle nuts, panhard, etc, hardware is torqued to spec.
Movement at the top and bottom of the wheel can indicate either wheel or trunnion bearing play. Movement at the sides (3 and 9 o'clock) isolates the wheel bearings better, although you have to take into account and look for play in other parts such as tie rod ends, steering box, etc.
^THIS^
My wooblems have always been one of the panhard nuts coming a bit loose. Second is wheel bearings, third is steering arm nuts. Put #3 at #1 for staying alive.
:deadhorse:
Remember, there's a difference between static and dynamic torque. The torque values for fasteners are listed as dynamic torque. The difference is that dynamic can be (and usually is, on clean, dry threads) 70-80% of static torque. This happens for the same reason that a load requires less force to keep moving than it does to start one; it's all about friction.
We used to have problems with this all the time on the axle assembly lines. There were (a few) manual torque operations on the old lines. The operators were constantly breaking bolts/studs by stopping and starting the tightening operations. Once you start to tighten a fastener with a torque wrench, you can't stop until it's tight. If you do, you risk generating a higher breakaway torque, if sufficient clamping force has developed, than the installation requirement.
You can prove this to yourself, if you have a wrench that allows you to see the actual values while you're turning the wrench.
All of the previous plus steering stabilizer. I see you have a lift, probably bigger tires too? Anyway, check yer nuts and stabilizer could be old, not dampening anymore.
Post #1: "I just replaced the steering damper with an OME damper, no change."
Tire pressures
Definitely check the steering arm nuts and wheel bearings.
Tie Rods ends
Then track bar bolts.
Swing arm bushings
Sway bar bushings
:deadhorse:
Please do this forum a favor and keep on posting - when I read your comments I either nod my head in agreement or learn something new.
Are you sure it's not his Head Gasket in this case?
I wanted to reply with a wrap up as the wobble was fixed! I started with having @landtank replace the front wheel bearings as he checked them and they really needed replacing, he installed heavy duty Toyo bearings. But the wobble was still there. He came up to my house and he discovered some axle movement when I turned the steering wheel with the truck off, he figured out that my Panhard bushings were bad.
To complicate things the nut on the backside of the axle housing clevis broke free! Rick was able to cut a small bit off of the opening for the nut so we could get at it but was unable to free up the bolt. He suggested I call Kina at North Country Cruisers.
I went up to see Kina on Friday, what a cool place, and such a nice guy! He got the nut tack welded back on and replaced the bushings, I brought up new bolts and nuts and after replacing everything I had him tack the other nut and the washers for the bolts as well.
Now my 80 drives solid again and I couldn't be happier!
Thanks again @landtank and Kina at North country cruisers
It is so thoughtful when the problem that started the thread is solved and puts closure to a thread. I hate it when a thread is left dangling with no solution shown. Happens all the time. I know we all get terrific help here at no charge, the ones that help are pleased if the problem is solved. The rest of us watchers are pleased to learn from it. Thank you for the closure.
