Front end squeak
Rixeyville, VA
I've been battling a front end squeak on the 80 and cannot seem to pinpoint it.
The squeak is most prominent at 20-50mph and more so is long sweeper curves.
I checked the wheel bearings, repacked and reset preload. no fix.
The squeak certainly seems brake related as when it starts, if i apply the brakes the squeak goes away, let off the brakes and squeak comes back.
The pads are OE toyota and are in good shape, only 6 months old and not close to the pad wear idicator.
Any thoughts?
Brandon
Did you use silicone anti-squeal on the back of the pads and shims when you installed the new brakes?
-Spike
I'm going to bring this back up as yesterday i spent some time removing all the front pads, cleaning them up and re-applying disc brake quiet. Put everything back together and went for a drive.
No change whatsoever.....:mad:
Pulled everything out today. Cleaned, reapplied anti-squeak, and replaced. No squeak on test drive, keeping fingers crossed.
