Front end spacers???
Your geometry will double the thickness of the spacer at the wheel. e.g. A 1/2" spacer will equate to 1" of lift.
(The spacer part # is 43136-60020)
Not to hijack, but did the 2013 models come with the spacer?
That's odd. I'd say your initial measurement may have been off, or perhaps that KDSS may be to blame.
Have you measured the hub to fender distances in each wheel before and after the spacers? I ask, because if one side was off balance, and then you installed the spacers, it's very possible that you actually did gain more than 1/2",but simply can't observe it, because the KDSS is better or possibly more poorly balanced than it was previously.
I'd wondered about the KDSS.... if that's the case then opening the KDSS, rocking the suspension side to side and end to end, then giving it 20 min to adjust and then closing may result in slight increase in height with the new spacer. Easy to try.
Has anyone tried using the OEM spacer on the OME suspension? My front passenger tire clips the bumper near full articulation. It's not a huge problem but I was curious if anyone has tried the combo of the OME strut and OEM spacer?
