Front end clunk need advice
Did you ever get this problem solved? I have the exact same problem with a stock setup. I'm finding it very hard to track down.
No I haven't.
I am changing the steering knuckle bearings today. Lets see what happens after that.
Have you by any chance checked your bushes?
The front trailing arm makes a clunking noise now just like the one you describe....
It took me ages to realise what is was...
I am having a full poly bushes kit fitted next week.....
either way good luck with it....hope you get it sorted...
check for cracking of the chassis around where the steering box is mounted. it is common on early 80series in Oz.
Also check the bolts in the radius arms, mine clunks because the bolt holes through the radius arm mounting brackets have become a little elongated with wear.
Toby - factory rubber bushes are a better option than poly IMO, they will outlast the poly and flex better.
About the only thing I haven't checked are the bushes in the trailing arm.....I'm going to try to get at that this weekend. It's the only vehicle that I have running right now so I can't get to it during the work week.
I to have this mystry clunk. It happens when I accelerate from a dead stop and it is not all the time either and it is not drive train related either.
My first thoughts have been the radius arm bushings on the DS, it feels like it is in that area in the floor boards. It is not a major clunk but it is annoying as hell.
Your issue sounds like a loose body mount. Search on here for a fix. It seems to be a common issue.
I checked the body mounts last week. The clunk feels like it originates at the axle area.
I will have to check the mounts again, but I think they are good.
Changing bushings is not a bad idea in any 15 year old vehicle. Give it a shot, and report back.
The bolts are tight I cranked on them with a 2 foot breaker bar, way tighter than spec.
