Front Elocker Wiring Harness Routing??
San Diego
Website
youtube.com
Front Elocker Wiring Harness Routing?? Where does yours go?
ok, finished my front end rebuild and elocker install
i got the harness (from the plug in near the firewall to the elocker and indicator), found the plug on the rig to plug it into and cant really figure out a clean way to route it.
the harness has several little plastic plugs on it (to clip into something) and then it has to small metal square shape brackets that appear to attach to something as well
any help here? any pics of the OEM routing?
thanks
Anyone? I got the day off and wanted to button this up.
Thanks
On my '94 I went (from the engine compartment to the diff) along the inside of the wheel well, in front of the PS shock tower, angled back, crossed inside the frame rail, looped forward, along the stabilizer bar (using the two metal brackets CDan sold me) and to the diff. That way, the plastic clips lined up with holes, the foam protector seemd to be positioned where it would do the most good, nothing stretches during articulation. Getting the brackets tight to the stabilizer bar proved impossible, though.
Do you have the brackets for the sway-bar?
Not sure, there are 2 metal brackets on the harness (which i got from a guy on POR)
