Front Drum brakes?
lots of adjustment, but if everytning is working they stop great
my buddy ran 35s and drums for years on his fj40, no problem
3 speed gearing might suck on 33's
my bro is running my 33's on his drum brake 45 at the moment, and it stops better (why? i got no f%#$in clue) adjustment is the key i think.
adjustment is the key, bad part is you need to do it 2-3 times a year to keep them adjusted.
sounds like a nice buy tho!
When I had front drum brakes I swear I had to adjust those buggers every week!
I got really fast at it, but if I didn't do it, I knew to expect a high speed lane change
if I needed to nail the brakes.
For me, for street use, disk brakes were a #1 priority upgrade. For wheeling use, power steering was a #1 priority upgrade.
I have drums all around, and haven't had to adjust them for almost a year. Starting out with new, even shoes helps. It was harder when they had been adjusted poorly and the shoe linings had worn unevenly.
I have 4 drums on my 74' Pig. They stop fine when adjusted, they jump into the other lane when not adjusted. I am running 31's. I have 80% of the parts collected for the mini conversion, just waiting for the weather to get a little warmer. Hodag
Is first gear pretty high? I haven't found a list of the gear ratios for this trans. yet.
It only has 31's right now, but I'd sure like to stap on some 33 x 9.50's someday.
Ran my Pig for YEARS with drum brakes, 33x12.5 for the last 4 years...
Gotta love to adjust 'em, gotta get the cool adjuster tool that SOR sells.
I'd put it up on 'stands and do a really good adjust every now & then, in between I'd just tighten down the fronts one click when I thought they needed it
Just did the disc conversion a few months ago, almost miss all the adjusting.
i agree with idave, the 45 has been running for 1.5 years without adjustment in the drums, i think it needs it soon, the pedal is starting to get a little less progressive.
$400 running Pig with a 2F? Deal of the year...
DO send pics of that rascal when you get some. What a deal!
I'm running 33x9.50's on my '71 Pig now, with fresh drums. Stops great, but you DO need that cool SOR tool, and you DO need to adjust at least once a year.
For $400, I'm sure that thing needs other things besides a disc upgrade, the drums are fine. 3-speed has a waaay high first gear ratio, though, so on the street with 33's it will be OK, but forget rock crawling. Best you can do with that setup is easy 2-track wheelin'.
It has some electrical Gremelins, so right now, it doesn't run. It will though. I have a feeling its in the coil/points areas. The guy I bought it from had it since 95 and I swear, he was heart broken to get rid of it. On the other hand, his wife seemed a little happy. Yet, my wife encouraged the deal.
bet he's looking into wife swapping right about now
