front diff removed, odd findings?
DEN
So we pulled the busted front diff out today to check out what actually happened...it is a 99, so we figured we find the spider gears would be missing some chunks but instead we found the two pinions were fine..
the ring gear and pinion actually failed and it was missing atleast 6-8 teeth with a bunch of metal chunks inside the diff..
the backlash and preload measured out correctly.
I am now doubting the install of an ARB locker....I rarely wheel on trails where a front locker would be "necessary" to get from point A to point B....I was originally going to ARB the front to get the extra strength but now it looks like from what was found in my diff that it did not matter if it was 2 pinion, 4 pinion, or ARB'd it would have failed....
any ideas or thoughts on the findings?
The hypothesis is the ARB (please note Darren's/ATS4x4.com ARB/diff set-up advice) carrier provides increased rigidity for the ring gear. There have been R&P failures along with spider gear/pinion gear failure too.
If you are going to sell the rig then just order the complete front diff from your favorite Toyota parts person. And unless you have a line on a 4.30 R&P you're going to have to buy the complete front diff even if you want to ARB it...unless you're thinking about changing the R&P ratio to 4.56/4.88.
I don't want to sell the truck...I am staying with the 4.30 gearing so the new front assembly will be on its way soon...
Besides ringpinionbiz, has there been any other failures with the ARB installed in the front? Is the strength that ATS talks about by adding the ARB from reducing flex, strain? and on what part?
Yes as far as I know Carl is the only one to have the ARB'd front 100 diff fail. Everything is breakable with enough force applied. However I think for 99% of the harder trail users of the 100 are going to be AOK.
The ARB carrier provides increased support/rigidity for the ring gear (the ring gear bolts to the ARB carrier or visa versa I forget). The ARB carrier should be put in a lathe and checked for run-out and corrected as necessary according to Darren (this seems logical since you want two very flat surfaces mating to avoid preloading/distorting the ring gear!). To go one step further you should, again per Darren (I did this on mine), run a solid/machined pinion spacer instead of the OEM crush sleeve pinion spacer.
The choice is obviously yours but if you plan on wheeling the 100 I would do it right the first time and be done with it. Just my $.02.
Seen them fail both ways (spiders and ring/pinion) not with the arb though. Ring gear failure is usually because under load the gear deflects and then all of your setup measurements are shot and the rest is history.
Highly recommend when putting the new one together you add to the side pinion preload- higher than spec, fattest shims that will fit and keep the backlash correct. Bearing will take the extra preload and you have less chance of it deflecting under severe load. Other recommendation is replace crush sleeve with solid spacer, you may just never have to open the front diff again.
hth
ben
hth
ben
How do you determine higher then spec preload? Fsm wants you to be able to press the shims in 2/3 of the way by hand and beat in the rest of the way. Using the FSM technical system would one be safe by taken a factory set-up diff and increasing both shims by .0008 and calling it good?
Chris....I have seen you wheel and I remember how determined you were to make it up the Step. That is a good thing and you are hooked by the 4-wheeling sport.
That said, I do not think your statement about "not wheeling where a front locker is necessary" is 100% to your heart. The front locker helps (or is needed) on Pyeatt, the Gap, and many other obstacles you've traveled on.
Knowing who you are and what you want to do tells me your only option should be an ARB front diff. Should you of had it for the Gap you would have been thrilled when you went up the Step just like the 80's and with no risk of carnage.
So, I suggest you challenge your thoughts on your trucks intended future. :beer: I think the ARB is a must.
Basically the two fattest shims that will go in without excessive force, preload will usually increase about 5-10 in/lbs above factory spec. (Pinion preload + Side bearing preload). Only side preload will change.
No 2/3, if you can get it started and completely seated and have to work to do it that is the one you want.
Shotts, I think the ARB will go in my truck...I just wanted to let people know what we found...and hear some peoples experiences..
thanks guys
arb
a lot of broken 100's lately. We stock arb's, solid pinion preload spacers, and now have side shim kits too.
thanks guys
Just want to pose this out there.. do you think it is possible that fatigue is a factor in the front differential issues? I seem to recall someone saying Slee fixed 6-7 last year in snow. Are these all the early 100 series that just can't take it any more. Could it be they are deteriorating to some extent, due to a weak design, and finally one day "boom", even though were not abused.
Are we seeing the same failure rates for younger vehicles as we are for older ones?
