I prefer to run the bushings over the bearings in my spindles. My thinking is that the bushing won't fail catastrophically while the bearings certainly can. When I pulled my axle down the first time there were little rollers scattered around/etc. from abuse. I'm sure if you set them up right and maintain them that either is a good option and that there must have been some benefit to the rollers to justify the switch.
Regarding birfs, keep in mind that some of the "stronger" birfs for off-roading are actually softer metal so that they don't shatter and as a result they don't wear as long in fulltime rigs like ours. As I understand it some of the "off road" birfs are simply not heat treated while others use different alloys/etc. that help them handle high impact situations like sudden grip found under throttle, etc. Stock birfs are heat treated to harden the wear surfaces that the balls ride on which helps them last much longer in normal driving though that heat treating does make the bell/metals more brittle which can lead to exploding birfs if you really hammer them on the trail. Anyway, both types have their place and I assume there is more to it than this summary like number of splines, etc. etc. but I wanted to point out that you need to identify your use case and shop appropriately. Ie do you drive a part-time 4wd rig that sees heavy trail use, a trail only rig, a mostly hwy rig, etc.
