Front coil spacer- Before and after photos - Part number: 43136-60020
Here is a pic of factory spring spacer sitting on 275/70r18 BFG K02’s. No wheel spacers. Yes you will need an alignment after the spacer lift since the raised height will effect your front toe, camber and caster.
For the coil spacers, is it a pack of 2 or do I need to order 2?
I found the following and want to make sure I'm not putting 2 as quantity for no reason.
Coil spacer
You need to order two of them .... from what I recall....
Looking good.
I'd pair that with a mild 10mm spring spacer to the rear. Sure, you'll get some rake back, but not as much as stock. Some rake is not a bad thing anyways as it allows for load handling without the rear looking like it's dragging.
Plus it'll result in an overall ~1/2" lift! With all the goodness of the stock suspension setup.
Looking good.
Thanks! I’ll keep that in mind.
No wheel spacers. Only front coil spacers.
It is 305 + OEM Front coil spacer p/n
43136-60020
Great looking LC. I ordered the rom strut spacer and I’m looking to order aftermarket rims (I don’t love the stock silver). The method wheels I’m considering have a positive 25 offset and I believe that the OEM wheels have +56. This means that the methods will sit out about an inch. Any idea what size tire I can fit? Oh, and I’m considering going with a 17 rim but open to sticking with the 18.
After install coil spacer 43136-60020 + 305/60/R18 Nitto Terra Grappler G2 :
Excellent fitment! I think the 305/60r18s is an underrepresented size opportunity for LCs. Incrementally taller. More width and sidewall bulge to protect the wheels off-road. Wish more tire brands and models would offer this size.
I had the same tires on my previous LX470 that used the same 18x8 wheel size.
Does anyone know if this spacer will also fit my 2010 LC? Everything I see online shows it working only with 2013 and newer models... is there a different part for 2008-2012? Thanks!
Shock Absorber Sleeve - Toyota (43136-60020)​
I'm fairly sure they're compatible across all years of 200.
bumping an old thread as I'm curious if @parker019 (or anyone else) experienced rubbing with only the coil spacers + 305/60/18 tires on the stock 18" wheels?
@kbohtx
No rubbing after 55k miles on the set of nitto g2 terra grapplers with stock 18 wheels. Exception. Full L or R until steering wheel will no longer rotate will rub slightly. I just avoid ever doing full turn like that. Just back off the wheel the slightest fraction.
305/60/r18 nitto
Here is upper control arm where any rub will occur. This is after Over 55k miles since my OP in this thread.
Last week I replaced them with a new set. Same size. Still the same factory coil spacer.
Tire store said looks good.
Without coil spacer it could not accommodate this wide tire.
