So, I drove from work to get some lunch today, about 2 blocks. As I drove back to work, I got into the left turn lane, applied my brakes, and heard this popping, and then some grinding as my cruiser pulled hard right. I lost most of the power to my brakes as well, came to a stop, made my turn, and brakes were still weak. Drove around the block at work, after getting out and checking fluid level in brake reservoir, and condition of lines/possibility of leaks around wheels, front and rear. Everything was clean and checked out okay. No lights on dash about brakes, and no further noise from anywhere. And as I drove around the block, the power to my brakes eemed to even out again. So I drove home, about 18 mi on the highway.
Got home, and as I pulled in the driveway, heard a little bit of grinding as I turned right. Pulled the cruiser in the back, put it up on stands, felt the front hubs. Left was warm, right was too hot to keep a finger on it for more than a second. Let that cool down a little, and called ToothFairy. Started to take apart the front hub, burning my fingers, and found an interesting paste inside. Collected some of this substance, and found that it was indeed magnetic, very magnetic. So I know that axle grease, in and of itself, is not magnetic, therefore I have a problem.
Took off the hub nuts and the flat inner washer was spun on the spindle. Got that lined up again, thanks Butch, and off. Saw that I indeed had no more of anything that resembles a roller bearing. I have the outer and inner races of the outer bearing, and empty space. Pushed the hub back on as far as I could get it, rotated, and the rear bearing still seems okay. However, the inner race of the bearing seems to be welded onto the spindle shaft.
How do I get this thing off, without being myself and beating the living bujeezes out of it? I thought about using a torch, but is that really a good idea? Should I grind the races down until i can get the hub and rotor to pass the inner race? Do I need to take the entire knuckle off? I really need some help here.
