Cruiser failure; I had to get towed, now at dealership :(
NaterGator
On Gilligan's Island
Gainesville, FL
Doh! I was on my way to the airport to go to my brother's wedding when I noticed that my coasting 'vibe' had suddenly gotten alot worse. One second it was nothing noticeable and the next as soon as I let off the gas the whole car shuddered and the binding of the drivetrain was slowing my down almost like a dragging break... it completely went away when I got back on the gas though.
Remembering the u-joint failure carnage of Beno's friend, I immediately pulled off the interstate and proceeded to miss my first flight. I got under the cruiser and tried to visually see if anything was dry, loose, hot, worn, etc. Nothing seemed bad, the front shaft didn't seem to have much slack, etc. If I had had a CDL switch I would have just pulled the front shaft and kept driving; but alas I didn't.
So, long of the short is that I got towed 40 miles into Greenville to the Lexus dealership there. When I pulled it around after unload from the truck I got all kinds of new popping from the front end; oh unhappy me. I have no idea what they are going to say is wrong but I suspect it is going to be ujoints or pinon bearings. Wouldn't it be quite unusual to be eating u-joint on an OME medium lifted, landtank caster corrected FZJ?
I am an unhappy camper, and I have a feeling I'm going to wish I was home when this happened... the dealership isn't going to be cheap.
That sucks. I hope it's not too bad.
Sorry to hear that...:frown:! I hope it is not anything too major.
Keep us posted and try to enjoy the wedding.
Riley
...One second it was nothing noticeable and the next as soon as I let off the gas the whole car shuddered and the binding of the drivetrain was slowing my down almost like a dragging break...
Brake caliper loose?
Anyway, that sucks. Hope it gets worked out... :frown:
Nope, I thought of that because of the noise I was having (rattling while decel on washboard roads) and I took both wheels off and checked the brake calipers... nothing there and it only happens while coasting.
It has got to be something in the drivetrain. I'm just kinda peeved because it seems like for 99% of the people that do an OME medium lift and caster correction, there are little to no driveline vibes, and certainly not quick driveline component failures.
I've had the lift in for about 2 months now, and of course my cruiser fails on the way to my brothers wedding :mad:
$600 in plane tickets, $150 in tow truck fees, $???? in dealership costs. :doh:
You're going to be really unhappy when your dealership discovers that it is ujoints, and they tell you they will have to replace both driveshafts, as they don't do ujoint replacement. Order some ujoints and take it to a driveline shop. Much cheaper.
Are these the original joints?
You probably gained about 3" when you installed the OME medium lift.
What degree-correction did you drill the caster plates? Did you measure the front drive-line angle pre & post install?
Good luck!
-B-
They are original u-joints. Greased with fresh M1 synthetic about 3k miles ago. I would love to take it to a driveline shop with some new u-joints, but alas I'm in south Florida for the wedding now, and Greenville is about 90 miles from my job in NC when I get back, so I don't have the time or resources to do that. If they call me and say "it is the joints, you need new shafts" I'm going to tell them what page to lookup in the service manual as well as the part numbers for new "spider gears" as toyota calls them and I will make it clear what I want done. These guys seem nice though, and I doubt they will try to jerk me around.
Good luck!
-B-
I dunno if I gained that much, the truck sits pretty low and my fender measurements seem lower than many. I'm not sure why, but they do. I've also got addt'l weight up front in the form of a york compressor, so that should be even less of an effect. And I didn't use plates, I used landtank's bushing press template with OME bushings.
You could also always have the dealer diagnose the problem and then fix it yourself if you can. With all the dealer horror stories I've read on this board, I won't take either of my trucks to anyone I do not know and trust well. Good luck bro, and enjoy the wedding :beer:
If they replace the joints (which they may not do), make sure you get the driveshafts balanced. I doubt the dealership has a balancing machine.
OK. Did you get your caster measured after the OME bushings were installed? Did you measure the front drive-line angle before and after the caster correction?
I'm just trying to get as much information as possible since you were wondering what may have caused the as yet undetermined issue. If it is U-joints then you will want those measurements.
-B-
I had the caster measured before, it was -0.9 and -0.3. I did not measure it after, as the steering response felt perfect. I have to assume it is in the +2 range.
I did not measure diveline angles because I had a very slight groan/vibe, but hardly even noticeable. Another option is of course a worn tcase output bearing.
That is a possibility.
Was this after the lift and before the CC bushings? If yes, you should be fine and your drive angle should be fine.
Any chance you've been running with mismatched tyre sizes?
-B-
You can manually engage the Center diff and pull the shaft. If they give you too big a bill, tell them you will pay their time to pull the shaft and to put it in that back of the truck. Ask them to put the Tcase in lo while they move it into the parking lot.
Do a search, but I think while it is in low, you can either pull the fuse or pull the cable to the Tcase and it will keep the center diff locked when you go back to hi.
Another piece of the puzzle. To be fair I was slightly late for my flight so I might have been cruising in the 'spirited' range when this developed. Up around 83 perhaps.
My usually cruising speed is 70-75, so not that big of a difference, but enough to aggravate a looming problem, I suppose. Hence this is why I am almost certain it is driveline related, and pretty sure it is joints or a bearing.
The dealership called to tell me I'm overdue for my front axle service as well.... my brifs are silent when turning though. Do I let them do it, or trying to squeeze doing them myself in when I get home from work? Of course I want to do it myself and know it is done right, but I may not have time to do it until december... perhaps I should let them go ahead and do it. Grr, I hate moments in vehicle ownership like this :whoops:
-B-
Yes, after lift, before correction.
No chance of mismatched tire sized. I had a flat one morning (came out to my cruiser sitting on the rim :mad:) but I put the fullsized spare on, drove the shop and had a patch done for $5, then put the old tire back on. Always been running Revos since I've owned it.
I had thought about this... you put it in low, pull the fuse, put it back in high. However, I'm sorta in a pinch because I'm working a 24/7 fulltime job until the end of summer and when it finishes I have a 900 mile drive back home... there aren't alot of places I can do heavy car work while 'on the job' in NC, so my nuts are really in a vise on this one. I can take a day or two off and work on it on the blacktop, but since I am in Black Mountain, NC all I have are the (basic) tools I brought with me and a Napa a few miles away. :lol: I'm kinda screwed... :flipoff2:
Nate,
Knowing where you are in your life, I would say let them do it. This is not my usual response though. You should expect a hefty bill when you get back from the wedding but you will have transportation for your summer job and getting back to school this fall. For now, that is more important than the cost and you will have the opportunity to do this PM yourself in 3 or 4 years when it is due again.
My 2c.
-B-
The front axle depends on how bad it is and how much your time is worth. You can do it for about $200, they will probably want anywhere between $1200-$1500.
I would not have them do it if you think you can get it done in the next few months.
On the Manual CDL, You can drive without an axle and the CDL indefinitly. The manual CDL should take minutes and then you are done.
-B-, I think I agree. These people seem nice. They knew my voice when I called and transferred me to the correct service manager without me even having to say my name (something I can't say of my dealership in Tampa)
They seem on the ball, and I think this may be one of those times where I get some help from the parents because I am so royally screwed. Not to mention, the bill on this is probably going to be every penny of my earnings this summer.... oh well.
I think I'm gonna tell them to go ahead with the front axle service only because I doubt I'll get it done in Aug and December is a long ways off, and we'll see what they say about the noise. The service manager was like "yeah, our technician heard it and brought it right back, he said he was afraid he was destroying it"... lol. It really is a worrying feeling, this binding.
