Front Axle Thrust Washers Missing - Do I need them?
San Diego, CA
Took apart my front hubs and repacked bearings and new rotors etc. When I was putting it all together I realized that there were not any thrust washers.
I'm guessing this is not common. Is this something I need to take care of right away?
No washers on both sides? that seems odd. they're the large washers that have a bump on the inside that fits into a groove on the axle. I cant imagine you would be able to properly set and maintain bearing preload without them
so you just tightened the adj nut on the bare outer bearing? I think that might damage the bearing and/or put uneven pressure on it, not allowing it to set evenly.
If it's the outer, that's not much trouble at all to pop the flange off and put the thrust washer in. I would def. put it in. I don't think you will get an accurate tightening or preload on the bearing otherwise.
the sharp edges of the nut may damage the bearing too.
Nutty dangerous to drive around this way. New toyota washers are just a few bucks and you can replace it without even removing the tire.
DougM
Just a thought here, but when I rebuilt my axle a couple of months ago, I was missing one as well. Turns out it had stuck to the old bearing when we tore things down. Had to dig through a pile of shop towels and old parts to find it.
I think the thrust washer is an absolute requirement. You can probably get one from NAPA, or most autoparts stores, if you are not near a Toyota dealer. It's cheap, get it.
The thrust washer's indexing tab is there for a reason - don't leave home without it. BigMac
Mine too
Mine was missing the washer on both for ???? miles. I replaced them once I found out they were missing. Obviously you can run a while without them as the previous-previous owner last did the service. Apparently you can also run without a couple of cone washers as well as they were also missing.
I replaced everything, I figure they were there for a reason. I was surprised by the thickness of the thrust washers when I got them. Kinda explains why my craftsmen socket would barely grasp the inner lock nut. Replace it--- cheap insurance IMO.
Going to go look through the mess for these. Hopefully The PO didn't leave them off al this time.
I had to tweak with it all to get the preload that I was expecting. Maybe it wouldn't have been as big a pain if I had them on there.
DougM
That's what I'm thinking, got a call into the dealer already.
Thanks all!
mikeyb,
I had to re-tighten mine after a week so it's not like you are re-doing anything. :)
I would have an extra bearing on hand in case your old one is mashed up. you can use it later. easy to replace that stuff.
Going to go look through the mess for these. Hopefully The PO didn't leave them off all this time.
Well- Found them! They were stuck to the back of the old bearings. I even looked the bearings over for strange wear and didn't see them.
Looking at them though, there is a groove on the inside of both of them. I think I may replace them anyway. Is the groove supposed to be there? I was doing this job because my bearings were loose. Could it be that the trust washers were just worn?
Again- Thanks all.
Yep - flip them is fine but new is best.
