I have almost all the pasts and tools for the front axle service, but I cannot for the life of me find a brass punch/drift. I do have copper solid stock, but was wondering if anyone has tried it and found it too soft? If I cannot find a brass punch then I might try it anyway.
Well no go at harbor freight and sears for brass. I spent an hour looking in all the places they thought they were at. Also Sears has the 54mm socket online for 15.99 and says its in the store, but no they dont. They even looked online to see if it said they had it and it did. I have spent all day trying to locate that freakin 54mm and brass drift. Lowes or HD will be next tomorrow.
On the 54mm I heard once that someone used a Dana44 hub tool with and it worked. Does this sound familiar? I have one for my bronco. I would just go out and try, but I dont want to tear into it until I have everything to start so.....
Sears has that socket. It just isn't 54mm. Instead, it's 2 1/8 inches and 3/4 drive as well. So you need the socket and the adapter. Cruiserdan can get you the official Toyota SST for about $25. I have both.
At Harbor Freight, the drifts are on the same isle as the hammers. They come in a 2 pack. One of the drifts is round and the other is hexagonal.
Ya thats the first place the lady said they were at. I looked at every single item in that isle and there was nothing brass. Only steel. I could not even find a spot for it on the shelves according to price tags either. Oh well, my wife needs to goto Lowes anyway tomorrow so I will buy that one.
I did see the socket 2 1/8" as I read elsewhere but it was $29. I can order it from Sears online and its only $15 + 5 shipping. I will figure it out. I cant work on the LC until next wednesday anyway because of work...
Here, let me try to turn a bad thing good ... since you cannot find them anyway ... skip the drift thing all together; I've used them to rebuild my front and rear axles and they work but it is a real PITA. I had to take the drift to the grinder over and over to grind the face flat again so the striking surface would work well and basically it is just a real PITA to drift them in. I suggest getting a good set of "Bearing, Race and Seal Drivers" from Lisle or some similar tool manufacturer. The smaller set is not the one to get because it has nothing near the size of the inner axle bearings but the bigger set should take care of every bearing race or seal on your rig. HTH.
No, actually I find that a big brass hammer is the best for that. I hit it softly and square to the studs with the nuts still on and flush at the extreme end of the stud. It takes surprisingly little force for whatever reason.
Well a search of Lowes and Home Depot and nothing!!! This is nuts. Not even brass rods (well nothing bigger then 3/16"). I couldnt even find any alum dowels bigger the 3/8" Just venting frustration mostly...
