Front axle seals
Question about the front axle seals.
When I bought my 97 LC I purchased it from out of state. Had it inspected at the local dealer and the seller agreed to have the dealer fix everything they suggested. One of the items they suggested was to have the front axle seals replaced. So, they did that.
I was changing the oil and noticed that there was a lot of "gunk" which led me to wonder if the seals had failed or it was just never cleaned up after they replaced them. Took it back into a local dealer (different one) which put it up on the rack and immediately said the seals needed to be replaced. I told them to go ahead and do it, which they liked because it's about a $1200 job for them. Then I told them it would be under warranty because it was already done about 9 months. Suddenly they weren't so happy, but of course they have to it.
So, has anybody heard of those seals failing that quickly before?
I'm wondering if the first dealership never even did the work they said they did.
Any thoughts?
Sounds like they at least didn't replace the seals.
Good thing it's under warrenty. You could do this job your self for about $200 if it wasn't.
Yeah, that's what I was thinking Romer. Personally, I think they screwed me on it , billed me for the parts, and never replaced the seals.
I've got to start learning how to do some work on this thing so that I can make sure things are done right and at a reasonable cost.
I'm starting to look at it this way:
If I spent the $200 or so on parts, screwed up the job, and still had to take it in somewhere, I wouldn't even really lose any money. I'd have the parts paid for and would only need to pay the labor. Plus, I might actaully learn a little bit about working on these in the process.
This thread is in the maintenance section of the FAQ:
https://forum.ih8mud.com/showthread.php?t=78276
This is the job they should be doing. You can read it to ask the appropriate questions to make sure they are doing it correctly.
Any thoughts?
Post the part numbers that were used by both shops.
There are a several "seals" in the front axle assembly. There are wiper seals on the back of the knuckle. There is an inner axle tube seal that keeps the diff fluid out of the steering knuckle. There is a dust seal on the hub.
-B-
-B-
The second shop hasn't done it yet. I'll post the part numbers from the first shop when I get home and can look at my receipt. From what I understand, it was the small seal and large seal, but not the wiper seal on the back of the knuckle that were replaced. Will post later tonight.
-B-
Here's how the parts list reads. It was done under the description of "Reseal Leaking Trunion Seals" (Brake pads were also replaced while they were in there):
1 04434-60051 Gasket Kit, Fr Axle
2 90310-35010 Seal, Type S Oil
1 04465-60020 Pad Kit, Disc Brake, Fr
2 90311-62001 Seal, Type T Oil
2 43512-60090 Disc, Fr
Those are the correct parts to replace the inner axle tube seal (90310-35010), the wiper seals (in kit 04434-60051) and the wheel bearing grease seals on the back of the hub (90311-62001)
Done properly, this is a complete front axle service with new rotors and pads. They must have reused the trunion and wheel bearings which is not unusual. Most of us would recommend replacing the trunion (aka knuckle) bearings when this job is done. Many of us replace the wheel bearings too. I would guess that job was close to $2,000 at a Toyota dealer.
This is a 60k mile service and there is no way you should need it done within 9 months unless you drive a LOT of miles.
-B-
