Odd question but I'll ask anyway. Are the 80's front axles centered or are they offset to one side of the vehicle's centerline a "smidge." Just thought I noticed something odd this afternoon when I was out in the garage gazing lustfully at it from the front. PS wheel/tire seems to sit further outboard than the DS. Perhaps it's just a caster/camber issue...or I'm just seeing things. Didn't have enough time to investigate it further. Off to a Super Bowl party...
It could be caused by spring sag. If you are still running stock springs, it is probable that they have sagged below factory height. As the panhard bar is attached to the frame on the driver's side and the axle on the passenger's, when the frame is closer to the axle, it pushes the body/frame toward the driver's side. If it was higher than factory, the panhard bar would pull the body toward the passenger's side.
This is why when you lift your truck, in order to keep the axle centered, you either must have an adjustable or lengthened panhard, or a drop bracket in some apps.
