Front Axle Locked Up
Fzj80 1997
I bought a parts truck from some “I Buy junk cars” people that you see driving around sometimes last night. They had bought the truck earlier that day from some guy and towed it to their house. When I got there, I opened the door and was immediately hit with the smell of burnt axle fluid. I asked them if they had a dolly and they obviously said no. Transfer case was in high. I ended up buying it off them and instead of waiting for a tow with at least a dolly (didn’t want to wait; sun was down and I was in the middle of the ghetto), I said it’s probably ****ed anyway, I’ll just have them tow it home. After all, they offered... They followed me home (10 miles on the freeway), I got there first. As I saw them pull up, there was a trail of smoke coming from the front end. They pretended not to notice. Lol. Morning came and when it was time to park it in its final resting place, she moved a few feet and now she won’t budge. I disconnected the driveshafts and she still won’t move. The front end is completely bound up.
My main question is, is there anything else that will be messed up other than the front differential from this improper tow?
The VC (viscous coupler) in the transfer case is one prime target, I'd think. Plus more. There's a reason that they recommend against such antics.
Thst doesn't explain why the axle remains locked after no longer being physically tied to the TC by the prop shaft. If the truck was poorly maintained and lube levels or bearing adjustments in the front axle were jinky, then smae thing when a bearing otherwise runs dry.
Have you pulled the pads out of the calipers to be sure that's free?
Jack it up and get all 4 on jack stands, check to see if the drivetrain will turn both front and rear output flanges in fwd gears and reverse. This might help you rule out the tranny and transfer case. Are both front wheels locked up or just one side? I’d also drain the front gear oil and see what that looks like and see how much metal is on the plug. After that I’d dive into the birfs to see what is binding it up, it will all need to come apart anyway if it’s the front diff that’s damaged.
A bad VC will act like the CDL is locked, it will turn the front and rear DS’s together at the same rate. It may be shot, mine was, but I’m not sure you’d have one axle locked up as a result.
SNIP
Agree, just was trying to sort all this mess out. If I was him, I'd stilln take your advice to confirm was was and wasn't working after this epic trial by fire. If it wasn't a project before, it is now.
